News Corsair HydroCool 200 External H20 at MODTHEBOX
Discussion in 'Article Discussion' started by GreatOldOne, 21 Nov 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    MODTHEBOX has had a play around with Corsair's HydroCool system. Big splash, or damp squib?
    "An aluminum reservoir tank is positioned at the very rear of the unit and holds the coolant supply. One of the clear benefits of reservoirs is the ease of maintenance for filling and bleeding liquid. A small sensor has been inserted into the reservoir, which monitors the water level and will sound an alarm should the water reach below a safe operating level. The use of 90" L fittings seem to be a common theme inside the Corsair HydroCool 200, these fittings are known to decrease overall water flow. There are several locations in the unit where the use of these fittings could have been easily avoided."
    Full review here
Tags: Add Tags
