Hardware Corsair K70 RGB Rapidfire Review
Discussion in 'Article Discussion' started by Combatus, 21 Apr 2016.
  1. Combatus
    16 Feb 2009
  2. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    If only they did a wireless version I'd snap one up for me and another for a friend in an instant!
  3. Dedlite
    Dedlite What's a Dremel?
    4 Apr 2010
    Using a K70 RGB model, and wouldn't look to upgrade really. I'm using a Cherry Blue Switch model - I wonder if Corsair still offer different switch types? They used to.
    I'm loving the K70 RGB though (having used both a standard K70 andd a K90, in my WoW days) The light on these switches are definitely more durable than they used to be (on the 'old' K70)!
  4. vdbswong
    vdbswong It's a Hedgehod
    23 Apr 2009
    Comparing the pictures to my current K70 and the K70 RGB review, it looks like they've changed the font on the keycaps to be a little more... stand out, almost like a cross between the Razer keycaps and those big button phones you can get.
    Not sure if i like it tbh.
    EDIT: I skimmed over the bit where you already mentioned that in the article :(.
    Still not sure about it though.
  5. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Quick question: For <$100, is there a mechanical keyboard with cherry red (or this new silver)? I really REALLY don't need the flashing RGB crap, but backlit letters would be good.
  6. Dedlite
    4 Apr 2010
    Silver - no chance. Corsair have an exclusive license from Cherry for the next 6 months.
    I know Ducky do one with Red switches - it's worth Googling around for the cheapest price. :)
  7. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    There are plenty if all you are after is any mech keyboard with Cherry Reds and some backlighting... Just look at Scan and there were at least half a dozen different options as well as loads of Corsair refurbs for pretty good prices.
  8. DbD
    DbD Minimodder
    13 Dec 2007
Tags: Add Tags
