CORSAIR LAUNCHES WORLD’S FASTEST PRODUCTION DDR3 SOLUTION
Discussion in 'Industry News' started by Guest-16, 25 Jul 2008.
  1. Guest-16
    Guest-16 Guest
  2. kenco_uk
    28 Nov 2003
    2 x 1GB modules, btw. Link
    That's quite nippy.
  3. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    2.0v, that's seems pretty high for DDR3, .5v over JEDEC default of 1.5v. Although the speed you get is insane, 2.133GHz memory speed is pretty epic.
  4. Jasio
    Jasio Made in Canada
    27 Jun 2008
    While the technology it amazing and the ability to produce these frequencies is impressive, I'd prefer to see a more vigorous attempt at trying to make DDR3 mainstream and down into the DDR2 price range of 1:1 (2GB DDR2 kit == 2GB DD3 kit). The majority of consumers, and even "hardcore" overclockers and gamers aren't necessarily those who can afford to pop $4,000 down on a (rather unimpressive) 790i system. The overclockers choice was the P35, the middle of the road, and we are seeing similar trends with the P45. Bring DDR3 RAM to a reasonable price /in-line/ with the financial capabilities of a larger audience would go a lot further than trying to break the next frequency record.
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    that will happen, DDR3 is expensive at the moment as factories are switching over from producing DDR2 to DDR3. because of this move DDR2 will start to rise in price and DDR3 will drop in price.
    its a well know fact that mid-range gear sells the most, and considering the mid-range gear overclocks very well only those who want a massive e-peen purchase Nvidia chipset machines with SLI.
  6. GavX
    GavX New Member
    5 Apr 2008
    same as DDR2 really, I remember the switch over from DDR to DDR2, was years... but now it is here certainly for mainstream. I remember building my Athlon 939 system seeing DDR2 around and didn't have a clue why other motherboards didn't support it (back in my newbie days!) and that was at least 3 years ago, give it a year and it should be the norm certainly for gamers and OCers
