Other Corsair link system
Discussion in 'Software' started by Kovoet, 3 Mar 2013.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Well after getting the new case I decided to install the new H100i and the software does not seem to work. has anyone else had this problem and if so how did you rectify it.
    Thanks in advance
  2. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    So you do have the link cable connected to a spare internal usb header right?
  3. Kovoet
    26 Aug 2009
    That I do bud. It's the software that's not working
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    That was all I had mate, I do not have any i series stuff from Corsair. Odd that it doesn't work.
  5. GeorgeK
    18 Sep 2010
    What exactly's not working? Mine set up fine...
  6. Kovoet
    26 Aug 2009
    This is all I get. I have tried troubleshoot capabilities and it brings it up then a couple of seconds later it stops. Also tried different USB ports
  7. GeorgeK
    18 Sep 2010
    Odd... Have you downloaded the latest version from their website (actually come to think about it that's where you have to get it from isn't it?) Are there any errors in Device Manager?
  8. Kovoet
    26 Aug 2009
    nothing bud. Also corsair only have 2.2 for download at the moment.
  9. GeorgeK
    18 Sep 2010
    Are you running Windows 8?
  10. Kovoet
    26 Aug 2009
    Windows 7
    This is the furthest I get
  11. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    Im having trouble with it as well. Cant seem to control either of my fans. They are connected to the cable provided and its plugged into the block where it is meant to be. But cant see the options to control the fans? Was really looking forward to this bit software as I had heard good things. Slightly annoying.
    Any thoughts? Or could somebody post a screen shot of it working?
  12. GeorgeK
    18 Sep 2010
    I did have it working (and have been thinking about this kov honest) but have removed the cable from my system now I've got it up and running... I'll look into plugging it back in :thumb:
  13. TheJackal
    TheJackal Getting Old
    3 May 2009
    the new software was released the other day on there website much better for me
  14. Kovoet
    26 Aug 2009
    I have tried every version with no luck. Tried as administrator and turned the firewall off everything no luck
  15. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Perhaps you're missing something liek a .Net pack or Sivlerlight
  16. will_123
    2 Feb 2011
    I managed to get it working! Made sure the cable was in correctly took it out. And put it back in again...then boom! The fans appeared in Link! Its great my processor never goes over 60 while gaming on the low setting!
  17. Kovoet
    26 Aug 2009
    Right I had enough of this. I decided to put in my new PSU and redo all the cabling. Ran CCleaner deleted all of the old link system that was on my hard drive.
    Then I saw that there is an update with the link and installed it and hooray it's running perfectly. One thing I did not know it also checks the gfx card temps as well which is handy.
  18. GeorgeK
    18 Sep 2010
    Success! It's quite good to play around with but once I got mine set up like I wanted it I actually unplugged the cable to tidy stuff up a bit - might put it back in when I redo my psu / cabling in the near future too.
