Cases Corsair Obsidian Full Tower versus Silverstone FT02 mid tower
Discussion in 'Hardware' started by bhanja_trinanjan, 12 Jun 2011.
  1. bhanja_trinanjan
    bhanja_trinanjan What's a Dremel?
    15 Apr 2008
    Hello,
    Which one is better? Which has the better craftsmanship and materials?
    The more comprehensive manual?
    Is the FT02 big enough for long video cards?
    Which cabinet makes life easier while building a new system?
  2. bhanja_trinanjan
    15 Apr 2008
    Can the FT02 accomodate long graphics cards comfortably?
  3. Wira
    Wira Spoderman
    27 Jan 2011
    Tbh they're both large, expensive, high quality cases, which will fit any size GPU you throw at them.
    AFAIK
    EDIT. the FT02 accomodates 12" long GPU's, a gtx 590 is 11"
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Are you watercooling?
  5. bhanja_trinanjan
    15 Apr 2008
    The Silverstone manual says 12"cards max... I wonder how much room a GTX 580 / HD6970 takes..
    The Corsair is even bigger, but the FT02 has so many positive reviews going for it...
  6. bhanja_trinanjan
    15 Apr 2008
    No, I am not. I am going for stock air cooling.
  7. bhanja_trinanjan
    15 Apr 2008
    I am getting either a 6970 or a GTX 570 / 580. These cards are pretty long.. I would like to hear from FT02 users whether the case can take these cards without problems.
  8. Parge
    16 Jul 2010
    It can. A 6970 is long, but will easily fit in a FT02.
  9. mars-bar-man
    17 Apr 2009
    Get the FT02, it's the best aircooling case avilable.
  10. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'd also throw my vote in for the FT02, or the RV02-E (Identical internals!) depending on your flavour, as both perform equally as well (I'd suspect the RV02-E might actually be better, as it's on four feet, not those long runners on the FT02, but that's just speculation from the images)
  11. bagman
    bagman Minimodder
    18 Apr 2009
    FT02 for me, don't like the corsair cases not as refined as the older more established case manufactures
  12. Jipa
    5 Feb 2004
    First of all welcome to the forums, second of all PLEASE edit your posts rather than post three of them in a row and do not bump in case nobody answers within an hour, it's not a chat, it's a forum. It's also easy enough to find the graphic card lengths via a minute of googling. (HD 6990 is the longest out there at 12", 6950 and 6970 are both 10,5", etc)
    And back to the topic: having had both cases, I'd go for the FT02. It isn't as massive, it isn't aimed for water cooling (has better cooling when using air) and just looks better in my opinion. Both cases are very sturdy and well put together, and the 800D does come with the hot swap drive bay if you need such feature.
  13. mrbungle
    20 Sep 2004
    Then id say its major overkill.
  14. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    FT02 is my choice. I'm running it at the moment an a 580 fits in with loads of room to spare. It's not even CLOSE to a snug fit.
  15. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Expect on looks I agree completely. 800D only if you're going to watercool, it performs hideously when aircooled out of the box, though this can be somewhat remedied by adding/switching fans and modding, but it isn't something you get 300€ case for. FT02 all the way.
    Also, as 800D is built like a urban assault vehicle it isn't a particular pleasure to mod.
  16. Jipa
    5 Feb 2004
    Ofcourse there's also the 650D if you like the 800D's looks... Not as expensive, more reasonably sized and can still fit everything you'll ever need.
  17. bhanja_trinanjan
    15 Apr 2008
    One last question on the Silverstone FT02... Since the motherboard is installed @ 90degrees with the IO ports on top, don't you lose a lot of usable cable length with a USB mouse? And if the case is on a platform below your computer desk with the monitor above (on the desk surface), doesn't it become cumbersome to connect and remove gear to the various rear (in this case top) IO ports?
    This problem would be compounded if you have a drawer attached to the underside of your computer table with the FT02 beneath that drawer. I hope that you can visualize what I mean.
  18. Jipa
    5 Feb 2004
    You can always just buy extension cables of an USB-hub if that becomes a problem.
  19. bhanja_trinanjan
    15 Apr 2008
    Also considering the Silverstone TJ09 / TJ10.
    What is the max video card length that the TJ09/TJ10 can take?
  20. Wira
    Wira Spoderman
    27 Jan 2011
    google it :duh:
    Jipa likes this.
