Hardware Corsair One Pro Review
Discussion in 'Article Discussion' started by Dogbert666, 5 May 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    ethusiast instincts
    Don't you press F7 when you are done typing in Word?
  3. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    £2200 and 20FPS in 4K...what a complete rip.
    Rather SLI 2 GTX 1070s with a bog standard quad core and probably double that.
    Imagine your surprise plugging it into your nice new 4K TV, knowing nothing about PCs and then seeing a slide show.
    You would be confused and a bit angry I reckon.
    And no dust filters with the old chestnut of a workaround 'easy to remove side panels'
  4. David
    7 Apr 2009
    That's the first pre-built system in a long time that I actually like. I mean, I wouldn't actually buy it but it does look the part.
    So many ways to handle that, and yet you chose to be a d!ck about it. Well done. :rolleyes:
  5. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Ok kid.
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Looks great, but can build something faster, quieter, and easier to maintain for less. My own M1 system for example.
    Exceptional, I think not. Exceptional build quality perhaps, but 1080 performance for £2200 with all the other caveats. No way.
  7. Vault-Tec
    30 Aug 2015
    TBH the sort of audience this is aimed at there should be a 1080ti in there. Or at least the option.
    I've bought pre made in the past and would again, so long as it offered the spec I was after.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    Indeed and by dropping the 7700k in favour of a 7600k putting in a 1080ti instead of the 1080 it wouldn't even move the price by much.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    If you read the copy, the reviewer does say that the Ti is an option, for another £300 approx.
    To agree with what David says above, this is the first prebuilt I'd even consider, since buying an Acorn RiscPC over 20 years ago
  10. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Too expensive, performance not good enough, likely to be a bugger to keep that interior clean and nowhere to put my Asus Xonar Essence STX...
  11. Vault-Tec
    30 Aug 2015
    Ian - I had already read the review for this on several sites so I did not read it in full on here. The 1080Ti option must be new, because when Linus and OC3D had it it was not an option so it seems Corsair corrected that before BT got their hands on it :)
    With something like this it's difficult to justify calling it too expensive. It's a niche item, name your price, what some one is willing to pay etc etc.
    The only other company I know of right now making tiny rigs like this is Falcon NW and theirs would make your eyes water (the Tiki).
    For what it is I don't think the price is bad by any means. Knocking up rigs from parts and then comparing is equally invalid, IMO. Problem is when you do that you are not creating an exact replica, just something similar.
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    ..........and queue comments on price and how it could be built cheaper.
    Somebody on the market for a pre-built system doesn't care if you can make it cheaper. They want something that works out the box.
  13. RedFlames
    23 Apr 2009
    It's a nice technical achievement. Unlike the 'Coke Can' Mac Pro I don't immediately look at it and thing 'that's going to cook itself'.
    Would I buy one? probably not, but i'm probably not the intended audience of it.
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, I'm not going to buy one, but it's nice to see an off-the-shelf SFF PC like this anyway.
  15. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    I know a good handle of console gamers with no PC building or hardware knowledge but this running Windows whatever and Steam they've got a gaming machine they want. and some would pay silly money.
  16. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    The intended audience i.e. people with no clue about PC's and components.
    Loads Deus Ex, settings to max on their new shiny 4K TV.
    Why is it juddering?
    Takes back to retailer.
    Confusion on all sides.
  17. Paradigm Shifter
    10 May 2006
    Looks nice. Wouldn't buy one; I love my Fractal Design cases too much. Although The Bitfenix Prodigy is still the case I want for a mini-ITX system...
  18. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    I would like to see those rads sold seperately. I know they aren't the biggest but I can think of a few builds where such slim rads would be a godsend.
  19. Vault-Tec
    30 Aug 2015
    Checked the Corsair page last night, 1080Ti is still not an option BTW.
    Silverstone already do rads just like them :)
  20. MightyBenihana
    8 Sep 2011
    I did not know that, thanks.
Tags: Add Tags
