News Corsair One upgraded with Core i9, RTX hardware
Discussion in 'Article Discussion' started by bit-tech, 7 Jan 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. RedFlames
    23 Apr 2009
    Meanwhile the Mac Pro is...
    ...still a disaster.
  3. Gareth Halfacree
    4 Dec 2007
  4. RedFlames
    23 Apr 2009
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    May be using the same calendar as Intels 10nm
  6. RedFlames
    23 Apr 2009
    Maybe they're waiting on/wanting to use/were promised the first batch of the relevant 10nm cpus.
  7. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
  8. Gareth Halfacree
    4 Dec 2007
    Ain't modular, though, which was one of the promises.
  9. fix-the-spade
    4 Jul 2011
    It is too, the CPU, Ram and SSDs use sockets and everything. By Apple standards it may as well be Lego.
  10. Gareth Halfacree
    4 Dec 2007
    Ooh, that's actually better than I thought. I sit corrected.
  11. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Don't worry, Apple themselves do not accept that the CPU being socked means it is modular. If you need to replace that CPU, the ONLY way Apple will provide it is as an assembly with the motherboard. They treat it exactly as if it were a soldered part.
  12. RedFlames
    23 Apr 2009
    and if the laptops are any indicator the ssds are removeable/replaceable... but they're a proprietary connector/form factor so good luck slotting a 970 evo in there...
    plus aren't the slimline imacs glued together now? making getting at the innards in the first place a challenge...
  13. fix-the-spade
    4 Jul 2011
    Well, there is the small matter that you have to remove the glued in place screen, then put your fingers uncomfortably close to the entirely unshielded power supply to take it apart. So, it might be worth just leaving it to the geniuses, they're expendable.
  14. Gareth Halfacree
    4 Dec 2007
    I knew there had to be a catch! Good job, Apple! Brave! Innovative!
  15. adidan
    25 Mar 2009
    $3000 to $5000?!?
    Jog on.
  16. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    I believe that's why most of them are Ginger?
  17. ltkAlpha
    ltkAlpha What's a Dremel?
    28 Feb 2018
    Looking forward to the majority of reviews not mentioning thermals at all or doing so vaguely or in passing again.
Tags: Add Tags
