Hardware Corsair Scimitar Pro RGB Review
Discussion in 'Article Discussion' started by Dogbert666, 6 Feb 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    Nice review. I've got a Razer Naga, which is doing well. But if I need a replacement, then this looks like it!
  3. Vault-Tec
    30 Aug 2015
    I would have preferred it if Corsair could have made the yellow bit opaque white and put like two small LEDs behind it. That way you could have the accent any colour you wish.
    But hey, if you are reading Corsair maybe on the next one?
  4. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    I wonder if it might be an idea for mice manufacturers to put a controllable LED in the cable a inch from the mouse. That way you can easier see it since LED on mice are mostly obscured during use if they are on the body.
    Feel free to use this idea for free manufacturers, :)
Tags: Add Tags
