PSU Corsair TX650
Discussion in 'Hardware' started by shindead, 10 May 2015.
  1. shindead
    shindead New Member
    14 Aug 2014
    Does anybody here know much about the corsair tx650? I am looking to upgrade my GFX card at some point and Im not sure how this psu is limiting my choice? I am currently using a ATI/amd4870 which has 2 power lines going into it (not sure what voltage)
    But yeah anyone? :)
  2. TheMadDutchDude
    23 Aug 2013
    The PSU is a strong one, and should handle any new card you put in your system.
    What're you planning to upgrade to?
  3. shindead
    shindead New Member
    14 Aug 2014
    I currently have a Q6600 cpu so nothing amazing.... No point in spending loads of money if my cpu is going to hold me back. It can barely handle simple tasks :p
  4. MrTeal
    MrTeal Member
    27 Aug 2010
    IIRC, TX650s only have two 6+2pin PEG (PCIe) connectors, so that's one limiting factor, unless you are willing to use 4pin peripheral (molex) to PEG adapters.
  5. shindead
    shindead New Member
    14 Aug 2014
    is it a simple thing to do?
  6. Strudul
    Strudul ~
    31 May 2010
    Yeh, you just connect it.
    (Not that you would need to unless you went Xfire)
    TX650 is good (as long as you don't mind non-modular)
  7. TheMadDutchDude
    23 Aug 2013
    I would not advise those adapters... there's a very simple reason why PSUs only come with a certain amount of connectors.
  8. shindead
    shindead New Member
    14 Aug 2014
    Seeing as I am only looking into using one card until I buy an entirely new system. What am I really limited to? I don't need anything amazing as the most demanding game I play is league
    Sent from my iPhone using Tapatalk
  9. Strudul
    Strudul ~
    31 May 2010
    With a TX650 you are pretty much only limited by cable management.
    (It will be fine for any single GPU)
  10. shindead
    shindead New Member
    14 Aug 2014
    It is a mess in there! I wish I was a tidy person as Im sure I would sort it out :p
