News Corsair unveils ML Series magnetic bearing fans
Discussion in 'Article Discussion' started by Gareth Halfacree, 11 Jul 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    $40 for a fan?
    Holy shishkabob!
    (but those do look sexy though)
  3. wolfticket
    19 Apr 2008
    $40 for two fans. Up to $30.99 for a single "Pro" version.
  4. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    You might feel it's expensive, but if you seek silence you only have so many places to go.
    So if you got your fancy watercooler and that radiator needs some help.. well it would defeat the purpose to have a noisy fan on it, and you already spend the money on that watercooler and all.
  5. Parge
    16 Jul 2010
    Improved longevity? I mean, I don't think I've ever had a fan actually fail so I'm not sure I buy that as a USP.
    Quieter fans are always nice though - will be interesting to see how they stack up against other premium fans (Industrial PPCs etc)
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    What I don't understand is that while they are releasing these ML fans with LEDs, why their other upcoming fans (SP120's and HD120's) which feature RGB LEDs (x4 and x12 respectively) are not using the ML design... Surely Corsair could offer RGB LEDs on their ML series?
    Oh well... I guess that will be 2017's money spinner. :(
  7. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    Over time fans often become more and more noisy, due to particles/dirt getting in the bearing as it slowly degrades from the constant movement.
    Some people replace them because of that increased noise.
  8. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    In 8 years I have had to replace about 8+ fans. Sure they were low cost $10 price range fans but I would rather pay 2x as much for fans that are better and last 2x as long.
  9. Guest-16
    Guest-16 Guest
    By the time I've needed to replace a fan I would have chucked it out anyway. I'd really need to see/hear one to be convinced they are better than Noctua or other. Really miss my Panaflo LA1s
  10. Taua
    Taua What's a Dremel?
    20 Sep 2014
    maglev fans are nothing new, they've been in computers for many years already (sunon) unless this is something different? The noise is generated mostly by the movement of air/the fan blades anyhow, and reliability is already not a concern with higher end fans. Oh well, perhaps Dyson could get in on the action and create a bunch of fans that use 'air multiplier' effect via air pipes from a pump? No spinning blades!
  11. Gareth Halfacree
    4 Dec 2007
    Ahem:
    :p
  12. Taua
    20 Sep 2014
    fair enough :p
  13. LennyRhys
    LennyRhys Oink!
    16 May 2011
    You certainly don't have to pay $30-something for silence.
    I can't believe that after all the research that has been done on computer fans, vendors are still pulling the "even quieter" trump card to make sales. It's utterly ridiculous. Good quality bearings don't make noise, so changing the bearings won't make a fan quieter.
    Note: the best and quietest fans I have are all dual ball bearing fans - Thermarlight TY-143, Gentle typhoon, various Nidec and Delta fans, and most recently some frickin' sensational San Aces. The more cooling you have, the more air noise you will have. No bearing technology will ever change that.
