Memory Corsair Value Select Ram
Discussion in 'Hardware' started by slackda, 18 Nov 2010.
  1. slackda
    slackda Is aiming for a Headshot!
    23 Aug 2010
    Hi, i did a quick search and couldn't seem to come up with anyhting on the topic of the Value select ram.
    I Currently have 1 Stick of Corsair Memory Value Select 2GB DDR3 1333Mhz CAS 9 Dual Channel Desktop
    http://www.scan.co.uk/products/2gb-...-10600-(1333)-non-ecc-unbuffered-cas-9-9-9-24
    I have had Value select in my Last pc orignal DDR, never had any issues with it, but never O/c, not really planning on O/c atm as PC is doing the job.
    What are your thoughts on this ram, im thinking of upping to at least 4gb, but may go the whole hog and buy 3 more sticks upping to 8Gb. worth sticking with the VS stuff or going for something with oc potential? and ebaying the existing stick.
  2. Tangster
    23 May 2009
    Buy a 4GB dual channel kit. Value select is decent enough, but if you're going to overclock then XMS3 or similar(HyperX, OCZ something, etc,etc) at 1600 is the way to go.
  3. bulldogjeff
    2 Mar 2010
    I don't know about the ddr3, but if it's anything like the ddr2 it will overclock like a demon. I had the 667mhz running at 824mhz. I didn't even know it was that high until I was running CPU-z to check an overclocked CPU.
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Corsair sells single sticks?!
  5. adam_bagpuss
    24 Apr 2009
    yeah 4GB kits are only 2 single sticks together didint you know lol.
    idd just get a second stick of the same stuff for 4GB it will be fine.
    ive used the value stuff and its perfectly fine at its rated speed + its life time warraty anyway
