Memory Corsair Vengance heatsink clearance
Discussion in 'Hardware' started by Duffer, 26 Dec 2011.
  1. Duffer
    Duffer New Member
    8 Dec 2010
    A little earlier, i ordered a load of new PC bits for myself; 2500k, ga-z68ap-d3, 8gb Corsair Vengance Jet Black and a Gelid Tranquilo.
    It's only now occured to me that i may experience problems with the RAM heatsink not fitting under the CPU cooler :duh:
    What is the consensus? Do you reckon it'll fit? Or should i get on the phone and try to amend my order?
    Merry Christmas, all!
  2. KidMod-Southpaw
    28 Sep 2010
    It will fit as long as you install the memory before the cooler, and just to be safe, don't install the memory in the closest slot.
  3. barney magru
    barney magru New Member
    6 Oct 2010
    I'm in same position, picking up components as of tonight for new system. I went with the gskill ripjaws (F3-12800CL9D-8GBXL) because of the height of the corsair heatsink. Seen as both supposed to be spot on, went with the lower heatfins just incase causes any issue
  4. N17 dizzi
    N17 dizzi Well-Known Member
    23 Mar 2011
    You should be okay, check which slots are for dual channel on the board manufacturers website
  5. AoE
    AoE New Member
    4 Oct 2011
    I have 8GB Vengence in black also and the 1st stick is snog with the gelid tranquillo, by this I mean its clearly adding tension but memory is fine as its being read by computer etc.
  6. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Couldnt you have just ordered the low profile vengeance? (Unless of course you did, in which case you shouldnt have any issues at all.) i havent seen a heatsink yet that doesnt clear standard height RAM sticks
    Elaborate heatsinks on RAM are massively overated imo.
  7. Duffer
    Duffer New Member
    8 Dec 2010
    Thanks for the input, all!
    I've bought this memory. I didn't choose it because of the heatsink - it came as part of a "today only" offer. I was planning to but the XMS memory...
  8. Tangster
    23 May 2009
    A Gelid Tranquillio will probably obscure the 1st memory slot, use the other 2 and you'll be fine.
    It's fouled this slot in my old AM3 build, my previous 1366 build(asus P6T deluxe V2) and both of the MSI 1155 build's in my signature.
    Of course standard height modules will fit fine.
  9. lil chris
    lil chris New Member
    19 May 2010
    It depends which motherboard you are using duffer.I am using a Asus P8P67 and on that the reccomended sockets are A2 & B2 which are the farthest from the cpu.I have the same problem with the cooler, I have just bought 8GB of vengance 9-9-9-24 memory sticks on today only to replace my 4Gb from my original build earlier in the year. Unfortunately I forgot my 4gb is 8-8-8-24 or I could have at least used one stick in the B1 socket as single channel and had 10GB. Anyway 8Gb is big enough for me at the moment.
  10. N17 dizzi
    23 Mar 2011
    I bought a Z68A-GD55 and dual channel is the 1st and 3rd occupied or all 4. So I bought 2 LP vengeance for some 16GB madness!
  11. Duffer
    Duffer New Member
    8 Dec 2010
    OK, i've checked the Motherboard manual on the Gigabyte website. The memory slots to use are numbers 1 and 3 (working from right-to-left). So the slot closest to the CPU will be empty.
    Sounds like i'll be ok then! Thanks for the input, chaps.
  12. rob the bank
    rob the bank New Member
    13 Mar 2010
    Just pull the heatsinks off, just prise the end with a small screwdriver, once you have them off you will see there was no thermal paste between the surfaces just some white sticky pads.
    They are just for show, makes no difference at all.
    But keep them, as you would need to re-fit for a warranty claim.
  13. Duffer
    Duffer New Member
    8 Dec 2010
    Thank you very much for the info! That's the first time i've heard that... I'll have a good look when they get here. Buy yourself a pint, from me. :thumb:
  14. N17 dizzi
    23 Mar 2011
    Do Corsair inspect items before replacing them to see if someone has been prising heatsinks off with screwdrivers?
  15. feathers
    feathers Well-Known Member
    11 Apr 2009
    Makes me glad I use liquid cooling.
  16. Duffer
    Duffer New Member
    8 Dec 2010
    Thanks for all the help, chaps.
    Just a little update for future reference - Everything fits just fine!
    The memory slot closest to the CPU isn't used with 2 stick of RAM. So the cooler fits just fine. I has to install the cooler first, followed by the RAM, and finally the cooler fan. A bit conveluted, but it all fitted in the end.
    Nice shiny new PC to play with, now! I;m just waiting for Crysis to download over my pittiful internet connection, now...
