Hardware Corsair Vengeance 1300 Review
Discussion in 'Article Discussion' started by brumgrunt, 23 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Eiffie
    Eiffie What's a Dremel?
    11 Oct 2010
    Could a photo of the plugs on headset reviews be shown? The article mentions it doesn't feature a USB sound card connector but does that mean a standard 3.5mm jack is on the end? Is there more than 1 connector to account for the microphone? If either a photo could be added in future reviews or please always list the connector types and amounts for headsets I would greatly appreciate it.
  3. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Yes, it's regular 3.5mm jacks - one for the mic (output), one for the headphones (input)
  4. Eiffie
    11 Oct 2010
    Thank you.
  5. Bokonist
    Bokonist What's a Dremel?
    2 Mar 2011
    Nice review, I'm looking for a headset at the moment. I liked the 'sound' of the Vulcan but I use Freetrack for flight sims and racing games. These seem to be close in quality but the shape of the headband (on the corsiar) looks a bit easier to build a clip for.
  6. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    65dos. Nice.
  7. TheDarkSide
    TheDarkSide What's a Dremel?
    22 Feb 2011
    "we don’t hand them out as regular as some.."
    Pretty sure i know who you're implying here. And i agree, when awards are handed out to nearly every product they just lose their meaning.
  8. rogerrabbits
    rogerrabbits What's a Dremel?
    24 May 2011
    Increasing the volume of headphones to get rid of external noise is one of the most common ways people permanently damage their hearing.
  9. eVoPhantom
    eVoPhantom What's a Dremel?
    21 Jul 2010
    I have the 1500 versions and can tell you there is certainly no problem with lack of volume, I found that I had to tweak the EQ so that the highs didn't deafen me! Overall I am happy with them, they are certainly better than the creatives ones I had before. They are very comfortable, they seem to produce accurate rather than overblown bass.
  10. Guest-23315
    Guest-23315 Guest
    I've just picked up one of these and its fab. Comfy, easy to use, good long cables, good audio/mic quality.
    My only slight niggle is that the top volume level could do with being just a notch higher. It's not punchy enough when you try to listen to music. Otherwise, much recommended.
  11. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Nice long cables and very comfy. Mic is a bit close to the face and can be very sensitive. Biggest complaint is the cables are prone to fraying inside the left ear, losing sound out of one side.
Tags: Add Tags
