Memory Corsair Vengeance 1866 won't run at stock speeds (X79 + 3930K)
Discussion in 'Tech Support' started by Seb.F, 13 Apr 2012.
  1. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    Hi guys, spec as follows:
    X79-UD5
    3930K
    32GB (8 x 4GB) Corsair Vengeance 1866Mhz
    GTX 680
    256GB Crucial M4
    Basically, was running fine with 4x 4GB sticks on vengeance for the last 3 months, stuck in the other 4, boot looped.
    Reset CMOS, left the CPU clock alone and set XMP to 1866, boot loop.
    Changed RAM voltage to 1.55V, IMC to 1V, VTT to 1.2V, set XMP back to 1866, still boot loops.
    Anything I'm doing wrong here?
    Edit: Memtested fine, motherboard can see 32GB on both 1333 and 1600.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Try upping the VTT a bit more, upto about 1.25V. I'm guessing before adding the additional 4 sticks it worked fine at 1866?
  3. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    Yep, was working fine, and each set works just fine at 1866 on its own too. Just when they are combined.
  4. noizdaemon666
    15 Jun 2010
    I'm guessing it's a VTT issue. As mentioned up that a bit more and see if it helps. VTT is for the memory controller and stuff hence me saying up it, just in case you didn't know :)
    Edit: Leave everything else as you had it.
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    which bios are you on? the latest is F10
  6. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    Yep I'm on F10 :)
    Will try upping the VTT a tad more.
  7. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    Still boot loops with a reset CMOS and the only things changed are 1.25V VTT and 1.2V IMC voltages
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I can't get my ram to run at 1866 either, currently running at 1600mhz. (2500K)
    Same ram as yourself but I have just 2 x 4gb.
    I haven't tinkered with any additional voltages out of laziness really, that and the fact that I read somewhere you don't get much of a boost anyways.
    I had a similar issue when I ran AMD and my 1600mhz ddr3 wouldn't run either at stock, had to run at 1333mhz
  9. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    That sucks a bit. Ideally I wanted to be running the same speeds as before. I had VTT at 1.05V and IMC at 0.97 before, now it won't even run the 32GB on 1.25/1.2 :(
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Just recall when I was running 4 x 2gb on my old system I had to drop the timings from 1T to 2T or it wouldn't boot.
  11. Seb.F
    Seb.F Minimodder
    17 Nov 2011
    I'm going to try and really lay off on the timings and see what that does. I'm trying to run them at stock timings on 1866, perhaps the IMC just isn't up to it.
  12. andyb123
    andyb123 What's a Dremel?
    10 Mar 2011
    there is definitely something amiss in there somewhere, I didn't have to overvolt anything to get my 1866 memory working (X79-UD3 + 3930K), so I suggest you have a faulty bit of hardware in there somewhere - mobo or CPU
  13. Pookeyhead
    30 Jan 2004
    Does it boot when manually set to 1600 or slower?
    Work your way through this as well.
  14. Guest-16
    Guest-16 Guest
    I agree! Buy a proper X79! ;):D
  15. noizdaemon666
    15 Jun 2010
    @OP when you've tried the sets individually, did you try them in both sets of slots? So say you had them in RAM slots 1, 3, 5, 7, did you try 2, 4, 6, 8?
