Hardware Corsair Void RGB Wireless Review
Discussion in 'Article Discussion' started by Combatus, 4 Feb 2016.
  1. Combatus
    16 Feb 2009
  2. David
    7 Apr 2009
    When I saw the link in the forums, I was expecting a wireless keyboard with some kind of epic LiPo battery to run the lighting.
    Finding out that it is a review of a headset was a little deflating, if I'm honest. :lol:
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    Trying to figure out how you see the nice RGB lights when wearing them....???
    Are they just for the amusement of others or something or do they come supplied with a nice Corsair branded free standing mirror to admire yourself in them?
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Sadly not but I'll pass on the suggestion. It really is just for others, so my advice would be to set them to flash in all sorts of colours very fast - as annoying as possible :D
  5. David
    7 Apr 2009
    Hmm, set to maximum annoyance and then render yourself incapable of hearing the approach of the missus/gf/whoever as they come tw@t you on the noggin with something weighty.
    I sense a flaw in your plan. :lol:
  6. Hustler
    Hustler Minimodder
    8 Aug 2005
    Hence the need for a mirror to warn of approaching danger.
    Corsair really haven't thought this through. :)
  7. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Stick a 5 pence LED on anything these days and folk will lap it up. I really hope they release under-seat lighting soon.
  8. David
    7 Apr 2009
    For when you drop your Corn Dog? :p
  9. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Here is a situational question... I have a Blue Snowball Mic which often sits on my desk... With that in mind would you recommend a gaming headset such as this Corsair unit or to use the desk mic and go with a standard wireless set of audio headphones such as the Sennheiser RS120 II's for example?
  10. rollo
    rollo Modder
    16 May 2008
    Not sure how a headset with a Crackle you said in voice chat can get a recommended award when its main function which it does not full fill very well acording to your own words it may annoy others.
    Rest of the headset is surely irelivent if the Mic the Key point in buying a headset has this annoying feature.
    Crackle when not talking imagine that on skype in a long convo you would take the product back as defective surely.
  11. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    I got these because of the wireless aspect. I've gone through 9 headsets in 2 years because of the trailing wires on conventional types. When you turn the RGB crap off, you can get a good 22-24 hours of use before the battery dies, compared to the 7-8 with the RGB crap on.
    There is one downside to turning the RGB off though, it's on the same circuit as the LED mic mute indicator which means no indicator without the RGB. But, missing the indicator is a small thing to get almost 3 times the battery life.
Tags: Add Tags
