PSU Corsair vx550w PSU and asus P6T SE incompatibility
Discussion in 'Hardware' started by onthejazz, 23 Feb 2010.
  1. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    I have been looking into purchasing a '550W Corsair CMPSU-550VXUK' from scan on one of their daily deals. But then while looking on ebay for a price comparison I see this piece of information for a Corsair TX 950W.
    ''This item was bought just over a week ago along with a few other components. Since putting my new Rig together, I have found there is an Incompatibility between this PSU and the Mobo I have, My Motherboard is an Asus P6T SE, From trolling the Corsair Forums, I have found there is a known compatibility issue between the 2 which freezes the computer. This PSU has been tested in another computer with the same spec, but has an Asus Rampage II Extreme Motherboard and worked perfectly. I am unaware of any other PSU + Mobo combinations that fault in this way.''
    I also have an Asus P6T SE motherboard, would I have any problems with the Corsair 550W PSU?
  2. Krikkit
    21 Jan 2003
    Doubtful. I'd be interested to know the reason for the incompatibility between the two, you would've thought it wouldn't matter.
    Does the TX950 use a single 12V rail? If so that could explain the troubles if the P6T is particularly fussy.
    Anyway, with all the folks who own these boards and the popularity of Corsair PSU's you would've heard if it were a widespread problem. I wouldn't worry. :)
    p.s. Will 550W really be enough for an i7 rig? What else are you going to be running?
  3. onthejazz
    17 Feb 2010
    It will be a video editing rig.
    Core i7 920
    6GB corsair XMS RAM
    3-4 HD
    5770 GPU
  4. mrbungle
    20 Sep 2004
    I use a p6t se with a HX850 which has a huge single rail.
    No problems.
  5. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I think 550W should be fine, but if you're doubtful bump up a bit and consider a modular PSU (I wish I had!). But I agree with Krikkit, I think that guy's misdiagnosed his problems. You also seem to be looking at a comment about a PSU you're not considering buying and worrying about the PSU that you are buying?
  6. onthejazz
    17 Feb 2010
    Thanks for the feedback.
