Cooling corsair watercooling question
Discussion in 'Hardware' started by kazama, 10 May 2007.
  1. kazama
    kazama What's a Dremel?
    9 Dec 2006
    im plan to shift to WC cause i dislike my cpu fan and cpu heatsink that collect dust and also make loud noise. it make my cpu overheat and shutdown my system several times.
    i wanna know, which one is better?. corsair nautilus 500 or corsair COOL?. im plan to take this system. i didnt have lots of choice for watercooling in my country just thermaltake, coolermaster and also corsair. just can get the prebuild system not the DIY system.
    give me some sugestion, thanks
  2. Guest-23315
    Guest-23315 Guest
    Nautilus 500!
    Bit-tech loved it, other sites love it, your CPU and your ears will to!
  3. kazama
    9 Dec 2006
    nautilus 500..pretty good too. external watercooling. ill think about it.
    how about corsair cool and others such as coolermaster and thermaltake?
  4. Guest-23315
    Guest-23315 Guest
    Nope. Don't even go there.
    A new HSF would be a much better investment.
  5. kazama
    9 Dec 2006
    you mean a heat sink fan?. you mean stay with air cooling is much better??
  6. Guest-23315
    Guest-23315 Guest
    Either fork out the cash or a proper watercooling system (£90+) or simply get a sub-£30 HSF, like a Scythe Infiniti or an Arctic Cooling freezer 7/64 Pro
  7. kazama
    9 Dec 2006
    im still considering the new hsf, but it have some problems which is the noise and dust and temps. i think if i got a new hsf..it still collect dust. i dont want to overclock my cpu, and just want have some low temp, and get a free from dust and noise. so which one is better.
