Case Mod - In Progress Cosmos 2 - 2in1 Edition [update: 170612 - Mainboard arrives/custom watercoolers ...]
Discussion in 'Project Logs' started by thechoozen, 3 Jan 2012.
  1. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Look's like this is going to be a awesome mod subbed.
    yassarikhan786 likes this.
  2. theoeyeo
    theoeyeo What's a Dremel?
    27 Nov 2011
    sub'd as i love multiple pcs in one box builds. Can't believevyou can just pop the mini itx in like that; you sure won't struggle forcspace inside. are you intendingvto run extension leads fot the mini-itx? or where you thinking of having both boards at the back of the case?
  3. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    The custom waterblock is awesome :D.
  4. thechoozen
    thechoozen Minimodder
    9 May 2006
    thx a lot m8´s!!! :thumb:
    ...yeah we´re pretty sure that everything will fit inside like we planned it, the position shown on the pictures will be the place where we´re going to mount the mainbase....in front of the mainbase is then still enough free space for a radiator + fan....and the ports will be connected to extension leads which them to the backside of the case...
    time for the next update :D
    not so much happened in the last days....but we already started to paint the first parts....
    and we also started to work on a custom 2in1 reservoir :thumb: it will be done out of black and clear plexiglas and will be placed in 2 of the drive bays....
  5. KidMod-Southpaw
    28 Sep 2010
    Very nice work, I can't wait to start my own airbrushing. You guys do a great job!
  6. yassarikhan786
    10 Aug 2011
    Brilliant work, love the air brushing.
  7. peteski
    peteski long live the pc
    8 Jun 2011
    great start to the mod mate. im loving that case at the moment and cant wait to see what you do with it .
    subed :rock: :rock: :rock:
  8. PcJunkie209
    PcJunkie209 What's a Dremel?
    3 Sep 2011
    Awesome work!!
  9. Kiliv
    Kiliv What's a Dremel?
    2 Sep 2011
    This is awesome mate, really interested to see how this mod turns out, subbed ^^
  10. thechoozen
    9 May 2006
    thanks a lot!!! :thumb:
    Today we got a nice packet from AquaTuning / Phobya for our Cosmos 2 Projects!
    For that we want to send out a big Thank you!! for their support and help over the past years :D:thumb:
    We already assembled the Pump for one of the wc loops with the Plexi Top we got from Aquatuning....
    Beside that we tested if one of the 200mm radiators would fit behind the front :confused: and what should i say :thumb::D just a few modifications had to be done to the inside of the case....
    and to the radiator.....:thumb::D
  11. peteski
    8 Jun 2011
    looking good m8 :rock: :rock: :rock:
  12. bond0071993
    bond0071993 What's a Dremel?
    9 Jul 2011
    nice mod i like it
  13. MaXimiZe_89
    MaXimiZe_89 What's a Dremel?
    7 Jan 2012
    It's coming along fantastically. You've got my attention for sure :clap:
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Great Cosmos 2 mod.
  15. yassarikhan786
    10 Aug 2011
    +1 on all of the above :D.
  16. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    2 inlets, and you plugged the outlet! :eyebrow:
    Just remember to switch before you put it in! :)
    Besides that, it looks great! :thumb:
  17. timmyzg
    timmyzg What's a Dremel?
    12 Jan 2012
    nice mod and a nice case, can't wait for more pictures :thumb:
  18. thechoozen
    9 May 2006
    thx m8´s!!!
    hehehe, yeah...that happen if you´re doing one thing (putting the plugs in) and already thinking of another thing (continue the process on the reservoir).....:wallbash:
    Time for the next update :thumb:
    First we continued the work on the radiator....so...our next step was, that we had to sand the side on which we cutted the ports away...after that we made a few brass plates which we could solder to the radiator....
    Then we had to sand that side of the radiator again so that we could continue with a layer of fresh paint....
    After putting a first layer of fresh paint on it...we couldn´t stop :D
    Beside that we also continued the building process of the reservoir....
    In the meantime....we cutted out a few more parts, so that we could start to glue them together....
  19. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Good luck with the jigsaw :D digi camo paint job looks awesome!
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This res is going to be awesome.
