Case Mod - In Progress Cosmos 2 - 2in1 Edition [update: 170612 - Mainboard arrives/custom watercoolers ...]
Discussion in 'Project Logs' started by thechoozen, 3 Jan 2012.
  1. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    love "urban camo" paint!
  2. thechoozen
    thechoozen Minimodder
    9 May 2006
    thx :clap:
    Today i´ve got the next update :rock:
    In the last days we spent a lot of time for the reservoir, but now it´s nearly finished...i say nearly because we´re going to add 2 plexiglas pieces (one on each side) so that we could mount and lock the reservoir inside the drive cage (but i tihnk that we will add them tomorrow) :thumb:
    Like already mentioned in the last post...we started to glue all parts together to a solid unit which we could use to seperate the reservoir into 2 chambers (one for each system) :thumb:
    after that we started to cut out a few plexiglas parts to build a box around the middle part....
    After that we continued with the next parts....a bigger piece of smoke grey plexiglas which we will use as final cover in front of the reservoir ...so that it will perfectly fit inside the drive bays....
    We also cut out 2 black plexiglas pieces which was already drilled and got threads cutted...they will be used as fill ports....
    Then we made 2 big holes into the the top of the reservoir and attached the plexi pieces from the inside :D
    finally we prepared and added a backside to the reservoir....
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks nice. Why is it wet?
  4. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Wetsanding maybe?
  5. KidMod-Southpaw
    28 Sep 2010
    What a cool res!
  6. Briaireous
    Briaireous What's a Dremel?
    29 Nov 2011
    I wanna see what some coolant in there looks like :rock:
  7. peteski
    peteski long live the pc
    8 Jun 2011
    man thats one of the best res iv seen :jawdrop: keep up the good work :rock: :rock: :rock:
  8. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Truly excellent work, and by hand too! You were certainly deserving of that Cosmos II already without finishing the mod! Can't wait to see where it ends up!
  9. PcJunkie209
    PcJunkie209 What's a Dremel?
    3 Sep 2011
    Awesome work! The rad looks perfect. :)
  10. thechoozen
    9 May 2006
    thx m8´s :clap:
    oh thats because we made a quick test before, just to see if there are any leaks....:thumb:
    me too, but i think it will take a few days until we reach that point....
    And now it´s time for an update again :thumb:
    In the last days we finished the work on the reservoir...therefor we had to add a small plexiglas rectangle to each side....so that we could mount the reservoir in the drive bay (and lock it´s position with the integrated mechanism)
    Beside that we also made a small piece of plexiglas which will be placed in front of the reservoir just to get a nice transition from the rounded hard disk quick bay things to our reservoir....(a bit hard to explain....just a little detail)
    we also made a first test with 1 led behind one of the reservoir chambers, just to see how bright it is and to get a better idea how it will look like.....
    For the Mini ITX System we are going to integrate....we still needed a place where we could place all those ports...after a bit of searching...we finally found it....
    we also made a nice cover for the hole....
    and started to integrate all ports (we need) in it....
    yassarikhan786 and Waynio like this.
  11. KidMod-Southpaw
    28 Sep 2010
    That's cool, well done! :thumb:
  12. peteski
    8 Jun 2011
    smart work keep it up cant wait for more :rock: :rock: :rock:
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome
    Awesome
    Awesome
    :D:clap:
    A new choozen project & looking good :).​
    Auto 5 star & rep :)
  14. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    damn nice idea for the res :thumb:
  15. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Nice work , but how did you get the res watertight ? Just heat ?
  16. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Amazing work, the res looks awesome :D.
  17. thechoozen
    9 May 2006
    thx m8´s!!! :thumb:
    no heat...just glue... a lot of it :D
    First we glued all those single layers onto each other ....and then we only had to glue it to the front, back and top of the reservoir...:D
    Time for the next update: :rock:
    After finishing the work on the reservoir we switched over to next little detail...this time a little badge which will replace the original Coolermaster Logo in the Front....
    Beside that, we cut out a few plexiglas parts, which we used to build a drive cage.
    Our cage fits inside a normal drive bay (for optical drives) and can hold 2 slim line Slot-In Drives.... :thumb:
    We also made a first grill for the lower part of the case....(where you could mount a 2x120mm rad)....
  18. theoeyeo
    theoeyeo What's a Dremel?
    27 Nov 2011
    that badge is nice, how'd you make that? cnc, etching?
  19. yassarikhan786
    10 Aug 2011
    That grill looks really nice :D.
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Definitely :D:rock:
