Case Mod - In Progress Cosmos Cruizer - Final Pics!
Discussion in 'Project Logs' started by Boddaker, 26 Jul 2012.
  1. lowfat
    lowfat Minimodder
    4 Jul 2013
    A+ on the unique wiring. I love the idea.
  2. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    Why paint it? It looks fine how it is. :)
    Seriously though amazing stuff. Love the wiring.
  3. morgansk
    morgansk I've got wood
    12 Jan 2013
    Clucking Bell, this is cooler than a penguins chilly bits! Love the brake pipe inspired wiring - curious about the SATA cables though - is it possible to buy new plugs for the wire ends and therefore manufacture your own cables, or are you cutting and splicing existing cables? I may need to do this on my current build so just wondering what your solution is.
    Cheers!
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Getting the wires trough those tubes should be fun:D
    Looks great so far. Always nice to see something new done with wirering.
  5. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Thanks everyone for the great comments!
    For the SATA cables, I'll be making my own custom-length cables, and just taking the plugs from the stock cables. They are really easy to take apart. Once you remove the top cover, the wires are just pressed into each slot. :)
  6. Boddaker
    30 Nov 2006
    More odds and ends accomplished over the weekend. Some progress on the wiring, getting the spark plug wire look for the 24pin ATX and the PCI-e cables...
    I threaded six wires through each 10mm UV orange hose and added spark plug boots to the ends. Straight boots for the PSU end...
    ...and angle boots for the other end.
    Here's a shot of the wires pulled through the panel. Connectors will be added during final assembly. And I'll have some chrome eyelets installed to finish off the holes.
    Will add the other four spark plug wires tonight.
  7. Boddaker
    30 Nov 2006
    Got all eight done...
    I originally had the PCIe bank routed in front of the res, but I didn't like it, so I'm toying with going in behind it. I think it looks more tidy, and it helps to hold them in place. But now they are a little too long, so I'll have to shorten them.
  8. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Looking different but nice :)
  9. Boddaker
    30 Nov 2006
    Another clean-up item checked off my list: Boxing in the top and front side bezels to hide all the ugly webbing and fiberglass remnants.
    I got a sheet of 1/16" ABS and cut out the main pieces after making rough templates.
    Then I cut a bunch of pieces for ribbing and support.
    After fitting a base piece, I started gluing in the ribs and support pieces with ABS cement.
    Now the main piece has something to glue to.
    A shot of the left side bezel front. You can see why it has to be covered!
    With the front cover in place. The first of many test fits.
    Mating the front piece with the top piece.
    The right side bezel is in much better shape than the other one, but still needs to be boxed.
    I simply mirrored the original pieces to make these.
    After many refits, especially on the front due to the proximity of the front grill and faceplate, I finally got everything glued up. Here's the whole top with both side panels on the case. I scuffed the boxed pieces up in preparation for paint.
    My OCD is thanking me!
  10. morgansk
    12 Jan 2013
    Love the spark plug wiring, really nice. Please post some pictures when you make your SATA cables, I need to alter one for my build so with your help I'll be able to complete mine when the time comes. Thanks!
  11. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Haha! I can relate.... Lookin real good buddy!
  12. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    ^might explain the massive lag in updates...^ :p
    Looking reall good, boddaker!
  13. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    This is coming along amazingly,you have stayed pretty close to your original brief and im am all about the detailing you have put in.
    Cracking.
  14. morgansk
    12 Jan 2013
    Could you tell me which brand cables you are using as donors? I took apart a couple this weekend and all I can say is they were not what I would call "easy". The outer shells came off fairly cleanly, but the wires were encased in clear plastic which was extremely difficult to remove, I can't see a way to do this without ruining it. Any advice gratefully received!
  15. Boddaker
    30 Nov 2006
    Ahh, you must be talking about the data cables. Those are tricky because like you said the connectors are molded in hard rubber or plastic. I've seen people shorten the cable by taking a section out of the center and splicing it back together, leaving the ends intact. But it takes a steady hand to re-solder those tiny wires. I'll be avoiding that, and just going with the Silverstone ultra thin ones. :p
    The wires I have going through the aluminum tubing are the SATA power cables coming from the PSU, and they are pretty easy to manipulate.
  16. B NEGATIVE
    8 Aug 2011
    If you want strippable SATA cables then the Akasa slims have removable plugs
  17. Boddaker
    30 Nov 2006
    Well, I spent the weekend cleaning up panels and doing last minute details so I can send everything out for paint. I'm finding it difficult to stop messing with things and just call it good lol. I could easily spend another month just doing trivial things, so I have to force myself to stop and just put the panel in the box, and let BS Mods do their magic. Looking forward to getting some color on it! :D
  18. Boddaker
    30 Nov 2006
    Been finishing up a lot of minor details over the last couple weeks, trying to get all the panels' imperfections filled and smooth. Also had to make final adjustments to other parts that I wouldn't be able to do without the panels. Finally got everything boxed up and shipped to BSMODS for paint yesterday. :D
    I hope it survives the trip, it's not like Bob and Rod don't have enough work to do already without having to perform reconstructive surgery as well.
    So with all the panels out for paint, I must now concentrate on getting all the metal pieces ready to be sent out to the platers. Here are all the parts to be chromed..
  19. hanssx2
    hanssx2 Minimodder
    1 May 2014
    Just read through your houle log,
    just stunning your work.
    You Sir have a lot of Fantasy
  20. sprintdmc
    sprintdmc What's a Dremel?
    16 Apr 2013
    Pure class!
