Case Mod - In Progress Cosmos Cruizer - Final Pics!
Discussion in 'Project Logs' started by Boddaker, 26 Jul 2012.
  1. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Sorry about the lack of posts, but due to the ridiculous amount of work still left to do on this case (and my site going down), I've been kinda preoccupied. So tossing a few pics up here and there is about all I can manage right now.
    Anyway, while I got parts out for paint and polish, I've been taking care of lots of little things, like this distributor cap mod. This is a piece that will serve as a cover for the 24pin ATX connector. The four "spark plug wires" will plug into this piece, with the actual connector on the other side.
    So I started with the terminals from an actual distributor cap, which I recently removed off my V-6 Xterra.
    I harvested four of the terminals from the donor cap.
    Lining them up how I'll be gluing them together...
    Drilling them out so the wires will pass through
    Fast forward past all the gluing, bondo, sanding, and smoothing, and we have this..
    And as a final parting shot, all the bracketry and support pieces that have been sanded and primed.
    That's all I got for now, but I will be getting some polished parts back tonight, so I'll be sure to post a shot of them. And then hopefully Bob will give me a painting update soon.
  2. Boddaker
    30 Nov 2006
    Got parts back from the polisher yesterday. Here are a couple teaser shots...
    Stainless pipe, before and after polishing..
    I assembled the grill first thing.
    I had the guy only polish the stainless pipes, grill pieces, top handle bars, and headers. I'll be taking care of the small stuff next week.
  3. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    My god that's purdy!
    Great to see some progress on this!
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    This gonna come with Ray-Bans? That's some mad bling right there! :D
  5. Boddaker
    30 Nov 2006
    Thanks guys.
    Here's a quick update on the ATX 24pin plug cover...
  6. Boddaker
    30 Nov 2006
  7. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    :jawdrop: wow that's a nice paintjob from bob, can't wait for the endresult... i'm curious how the sparkplugleeds wil look
  8. Boddaker
    30 Nov 2006
    More teaser shots from BS Mods...
    PPG Orange Vibrance base coat...
    Mid coat...
    Keyboard frame...
    A test piece showing the paint with clear coat...
    With just a couple weeks left until the lan, methinks I'm going to have a few sleepless nights ahead of me...
  9. Boddaker
    30 Nov 2006
    Another mini update and final paint teaser..
    Slight modification on the EK tube reservoir brackets. I didn't like how they looked, so I filled in all the cavities with epoxy putty to make them look more solid.
    Before..
    Filled..
    Sanded and primed..
    On the polishing front, I pretty much got all the small parts done over the weekend. All the tubes were really easy, but the 1/4" aluminum bars were pretty rough especially around the bends. I had to start with 80 grit on the orbital sander to get the sides flat again. Then I moved up to 120, then 220. After that, I switched to hand sanding with 400grit, then to a fine 3M Scotch-brite pad, and finally on to the polishing wheel using coarse and fine compounds. Here's a before and after shot..
    And finally I leave you with the paint teaser...
    This might be the last transmission until the LAN, because as soon as Bob delivers the case, I'll have zero time to be posting anything other than a quick FB pic.
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I have been waiting this since you started this project. Looks absolutely amazing!
  11. Boddaker
    30 Nov 2006
    Ok, another quick paint update...
    Bob has been taunting me for the past week with painting shenanigans, so I figured I might as well share..
    I was going to save these shots until after the case was done, but I just can't keep the fricken awesomeness under wraps! Bob really outdid himself on my flame grills..
    I literally cannot sit still I'm so excited to see all this in person. Should be arriving tonight!
  12. CMos
    CMos What's a Dremel?
    30 Mar 2009
    This machine is going to be so epic!!!
  13. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    wow, love the color! This is gonna look so good once finished :)
  14. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    this is very good man its pure porn i wish i had a paint boot
  15. morgansk
    morgansk I've got wood
    12 Jan 2013
    Clucking Bell, that paintjob looks superb - loving how the flames look!
  16. Boddaker
    30 Nov 2006
    Ok, so while I'm at work and not finishing my case, I figured I'd post some assembly pics..
    Bob came down and stayed all day Thursday to help me out, and got a crap-ton of stuff done while I was stuck at work. I can't thank him enough! :D
    Got the upholstery done on the interior panels while Bob slaved over the main panel covering..
    The wiring on this thing is taking forever. Feeding the wires through the alu pipes is a royal PITA! But the end result will be worth it..
    The back side of the SSD module, wiring up the drives and lighting..
    ATX cable pinned with connector..
    Motherboard 12v power cables pinned and numbered. Will run continuity checks on all wires to match them up on the other end.
    Other side of the panel, waiting for PSU.
    Covering the PSU cover..
    Got all the blocks on the board, after detailing them in white/orange.
    Manifold in place..
    Rigid tubing in place..
    Polished mesh scoop insert..
    Tonight will consist of more wiring. Hope to finish up the PSU so I can move on to installing the rest of the stainless tubing and fill.
  17. chilliewillie
    14 Apr 2014
    omg ;D this is porn
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    :jawdrop::jawdrop::jawdrop::jawdrop::jawdrop: :jawdrop: :jawdrop:
    This is so awesome. I have no words to describe how cool this project is.
    :rock:
  19. Nexxo
    23 Oct 2001
    Duuuuuuude!
    I mean... Duuuuuuuude!!! :jawdrop:
  20. Impatience
    Impatience Minimodder
    6 Apr 2014
    The attention to detail.. EVERYTHING is so awesome with this build! I just cant even.. :jawdrop:
