Case Mod - In Progress Cosmos Cruizer - Final Pics!
Discussion in 'Project Logs' started by Boddaker, 26 Jul 2012.
  1. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    That front grill looks amazing! Great update man, keep it up!
  2. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Wow-that looks realy good. Must see more. :)
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    whoooa, that front grill is awsome !
    But i might have seen this idea on a other Cosmos 2 build?
  4. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Thanks guys. Yes, Alain-s is doing a similar grill on his Bel-Air case. He is integrating it more into the stock front panel which looks awesome under the sliding door, whereas mine is replacing the front panel altogether. :)
  5. Asouter
    Asouter --------
    18 Jan 2012
    How strong are the parts you make with the foam and bondo ? Just wondering as I might have a go myself
    Crackin build BTW
  6. Boddaker
    30 Nov 2006
    The fiberglass parts I make from the foam and bondo forms are very strong and lightweight. Should be able to withstand several years of extreme gaming abuse. :thumb: :D :naughty:
    Asouter likes this.
  7. ziza
    ziza What's a Dremel?
    21 Dec 2010
    That front grill is really impressive, nice job.
    Waiting for the next updates.
  8. Boddaker
    30 Nov 2006
    Thanks ziza. Here is the next update... :)
    More Grill progress...
    Made my own metal spacers from 5/16" stainless steel tubing. I took this shot before I deburred the ends.
    And I got the top ends of the bars rounded. This was kinda tricky since they are offset, and I needed to have the all curves end in a straight line so it will mate up with the top faceplate.
    Here's a couple shots of the grill on the case..
    And an over-all wide shot.
    Hoping to have a productive weekend, as the weather should be very nice.
    Cheers!
  9. Da Vinci
    Da Vinci What's a Dremel?
    17 Feb 2013
    If you put as much effort into the rest of this build and finish as you have so far, this could be the next MDPC....... Fantastic.:clap:
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This is amazing. It allready looks so unreal,like it is not from this planet.
  11. KoSoVaR^
    19 Dec 2010
    I still love it :D!:dremel:
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    That's a cool as flip looking grill. :D:clap:
    Awesome transformation well underway. :)
  13. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Whoa. Dat grill looks stunning :cooldude: Looking forward to more progress!
  14. Combatus
    16 Feb 2009
    Awesome Brian! I must have a play with some fibreglass sometime!
  15. Boddaker
    30 Nov 2006
    Thanks Da Vinci, that means a lot!
    Thanks guys! I really like how it's turning out.
  16. Boddaker
    30 Nov 2006
    Well the weather did hold last weekend, but of course I got called into work on Saturday, robbing me of most of my modding time. But I did manage to get some work done on the front bezel. I started with a piece of 1/4" acrylic, mapping out the item placement.
    Here is what I'll be mounting in the bezel: 7" lcd touch screen, Lamptron Touch fan controller, a hot-swap 2.5" drive bay, a pair of USB 2.0 and USB 3.0 ports, and finally an ignition keyswitch in the lower center (not shown).
    Once I got things where I wanted, I began cutting out the holes, then filing down to a nice snug fit.
    I found one of these all-in-one units lying around (big mistake on its part!) and thought I could utilize it in some fashion.
    But I only wanted the 2.5" hdd bay.
    So it got extracted from the rest. It will get mounted just underneath the Lamptron fan controller.
    Here is a shot of the bezel after fitting the USB ports.
    I haven't purchased it yet, but I'm thinking something along the lines of this for the Ignition switch. It has four detents: Off, Acc, On, and Start (momentary). I can use the Acc to turn on fans, or the pumps prior to firing up the computer.
    Hoping to get mounting brackets made tonight, and possibly some finish work.
  17. alain-s
    alain-s Minimodder
    12 Jan 2011
    Looks great but why not try a start bottom
    Think that it will look great with the other chromed parts and the collor of the case.
  18. Boddaker
    30 Nov 2006
    Thanks alain, I thought about the ignition start buttons, but thought they were too similar to the standard case power buttons. Having an old-school key switch is more befitting the hotrod theme, and allows for more functionality with the extra positions. :)
  19. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    +1 for the Engine Start button. Is there enough room for both a key and the button?
    That would look awesome.
  20. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Amazing job on the grill, the project is looking great and I love your creativity. I look forward to seeing more updates.
