Case Mod - In Progress Cosmos Cruizer - Final Pics!
Discussion in 'Project Logs' started by Boddaker, 26 Jul 2012.
  1. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Ordered the 4-position key switch from Watson's Streetworks. Super fast shipping, only took 2 days from New Hampshire to CA.
    Drilled a 3/4" mounting hole in the front faceplate
    And did a quick pre-fit to see how it looks.
    Looks pretty good, however, if I can find a better looking finish nut without the knurled sides, I'll swap this one out. But it will suffice for now.
    I'm hoping to get the whole front bezel assembled and mounted on the case this weekend, and get the top panel to fit over it. This has been one of the most difficult parts of the build because the top front of the case is where everything meets, and is the most visible, so it has to line up perfectly. Not to mention I'm creating both the top panel and front bezel completely from scratch, which compounds the situation. I predict more trial fits in my near future! :)
  2. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Just read the whole log again and this great stuff! I love the top and front :)
  3. Boddaker
    30 Nov 2006
    Thanks Meelobee!
    Making more headway on the top panel and its mesh. I wanted to continue the lines from the front grill across the top, so I added some 1/8" aluminum bar to the top of the mesh piece.
    After cutting the bars to length, I proceeded to bend them to match the back curve of the mesh. Looking around the garage, I found a suitable pipe to bend the bar around.
    The bend in the mesh is not a perfect circular curve, so I just tweaked the bends until they matched up perfectly. Here's the first bar.
    And here are the rest of the pieces for the back, propped up on the mesh for a quick pic.
    Just had three more easy straight pieces to make for the center.
    Once all the pieces were made and the ends rounded, it was time to mount them to the mesh. These bars being only 1/8" thick, I had to use very small 2/56 size screws to fasten them down. So out came the 2/56 tap! A small piece of tape on the tap served as my depth gauge so I wouldn't go too far and bottom out. These taps are quite brittle and can break easily.
    And the resulting tapped hole...
    I'm using these tiny screws that have a large head and 1/8" shank, which allow me to use a piece of black acrylic behind the mesh as a backing.
    Got all the bars tapped and fastened to the mesh.
    Looks like the back pieces need a little adjustment.
    Threw the top main bars on to see how it looks.
    And a shot from the front. I'll need to secure the front part of the mesh down onto the panel so it doesn't stick up like this. The back part will be secured by the main bars themselves since the ends go through the mesh.
    Keep in mind this will look quite different when it's done. The 1/8" aluminum bars will be chromed and the mesh itself will be black, to mimic the look of the front. I'm debating whether to chrome the larger main bars as well, or paint them the same color as the rest of the case. Might make the smaller bars stand out more that way.
  4. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    That is some fine bending work you got going. very slick
  5. matiss
    matiss Minimodder
    24 Jun 2010
    Absolutly brilliant work
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    That's a heck of a gorgeous vent bod, shaping up really nice. :clap:
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Super bends! I love the way your mind works.
    Which is why this startled me:
    Is that not what a Dremel is for? To remove or modify unwanted things? Think outside the box, Brian. You know, just like you normally do. ;)
  8. Boddaker
    30 Nov 2006
    Thanks guys!
    I don't know, finding more efficient ways to achieve one's goal is a good example of thinking outside the box. If I can save myself a few hours of work by locating a better looking nut or suitable chrome trim ring in the plumbing dept, I'll do it! Of course, if all else fails, I know I can always pick up the dremel and mod what I have. :dremel:
  9. Boddaker
    30 Nov 2006
    Well, I didn't get to the primer stage, but I did get the top panel and front bezel to play nice together. So I was able to assemble the entire case and get a shot to see how it looks so far.
    A closer up shot of the front bezel featuring the 7" touch screen LCD, Lamptron Touch fan controller, and ignition key switch. :)
    So I guess this week will consist of mainly bodywork and smoothing out the top panel. I may get some time in on the right side door as well.
  10. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    It just looks so so very awesome!
    Brilliant job mate!
  11. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Superb! :jawdrop:
  12. Colossous
    Colossous Minimodder
    28 May 2007
    Great job as ever duder :)
  13. CMos
    CMos What's a Dremel?
    30 Mar 2009
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Brain melting out of ears from an awesome overload. :hehe:
    Looking sweet. :)
  15. Boddaker
    30 Nov 2006
    lol thanks guys. :D
    It's time for Bods-Mods Monday Morning Update... The only proven cure to the case of the Mondays!
    I was able to get the windowed side panel skinned with fiberglass over the weekend, and the other side scoop attached as well. Before laying down the fiberglass though, I needed to get the window opening dialed in. But before doing that, I had to add pieces to fill in all the open areas on the back side.
    I want the inside to be totally smooth, so I began adding thin pieces of ABS scavenged from the other door's webbing. These pieces were the perfect thickness to fill in the depression where the door hinge used to be.
    I also cut out a couple pieces to fill in the door handle cavities. Since they are on the bottom now, there is no reason to keep them.
    I cut the pieces from the other door, just above the holes, so they had the same bends. I beveled the edges so they sat right in.
    ...and glued them down.
    Another section around the window had to be filled in as well.
    Once these pieces were glued in place, I could fill in the in-between areas with more foam.
    Once I started thinking about the side scoop positioning and where the hole would be, I realized I didn't really need to cover up one of the handle cavities, as it would be cut away. Oh well.
    Cut out the hole with my trusty jig saw.
    The front side, after filling in all the remaining voids with more foam. I also rounded the window edges with my router, using a 3/8" round-over bit.
    I then cut out a piece of fiberglass cloth to fit.
    Couldn't pause to get any pics during the lay-up process, so here is the result. I mixed up a batch of resin and used a thickener so it wouldn't run down into the foam too much (spray foam isn't very dense and leaves some bubbles). I taped a piece of cardboard in the window area to give myself an edge to later place the clear window up against.
    After laying down the cloth, I used the remaining thickened resin to saturate all areas, then Mixed up a smaller batch of resin with a curing agent as a top coat. Once that was on, I set the scoop in place, added more thickener to the remaining resin and used it to reinforce the joint.
    After about an hour, I came back to the door and shaved off all the excess around the edges with a utility knife. The resin hadn't cured fully, so it was relatively easy to trim at this point.
    I hung the door on the case to see how it looked. It's hard to tell in pics since the resin is transparent, but it's pretty flat, There are a couple ripples here and there, but that will be taken care of with sanding and adding a bit of filler to flatten it all out.
    And with that, I think that is the last bit of fiberglassing I will have to do on this case. I still have one more panel to fabricate, but I will be using aluminum sheet for that (the back panel). Getting closer to starting work on the internals. Can't wait!
    Pranja likes this.
  16. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    This is. Just. Wow.
  17. Nutman
    21 Oct 2008
    Looks good!
    But how many brain cells did you lose using that resin? :)
  18. Pierre3400
    Pierre3400 What's a Dremel?
    22 Aug 2013
    That really looks amazing, so many ideas coming together, such great work. I cannot wait to see the finished product.
  19. Boddaker
    30 Nov 2006
    Thanks KrunchR!
    ...I've got a lovely bunch of coconuts.....
    Thanks Pierre! :)
  20. Boddaker
    30 Nov 2006
    Smallish update, just doing a lil bodywork on the suicide door panel...
    Smoothing it all out on the inside as well..
