Case Mod - In Progress "Cosmos Dragon" - 040809 - GC Online
Discussion in 'Project Logs' started by thechoozen, 23 Sep 2008.
  1. thechoozen
    thechoozen Active Member
    9 May 2006
    thx m8´s!!!
    today we checked everything and found out that the cable from the psu (original cable un modded) was broken so everytime you touch the cable the leds light up you let the cable loose they don´t work.....after we found out was the problem was it was easy to solve...just a new cable and everyting was fine....the spike from the sidepanel is also back in place so that we just had to rebuild the stolen front door....(thats a good result for such an exhibition...:thumb: )
    after we fixed the problems we made a first OC test to see how good the phenom performs and we could easily push it up to 3.9 ghz (without giving more voltage)....we also made a few benchmark runs in 3dmark06 and here is one of the results.....
  2. thechoozen
    9 May 2006
    today we started to overwork the next add on part for the cosmos....we started to disassemble the 5.1 box from a medusa headset ....beside that we already prepared a few plexi layers from which we build the new housing....
    i also managed to upload a short video from the cosmos @ the cebit ....
  3. The boy 4rm oz
    10 Apr 2008
    That is a very nice OC, nice work.
  4. thechoozen
    9 May 2006
    thx!
    today we did a bit of progress on the new Medusa 5.1 enclosure....we already drilled all holes for the Power LED, the Headsets and all other cables.....
    beside that we started to take out the inner part.....
    we also cut and glued some plexirods together.....as soon as they are sanded and polished we will make a cover for the small crossfire x bridge....
  5. The boy 4rm oz
    10 Apr 2008
    Even a custom Crossfire bridge cover, WOW.
  6. thechoozen
    9 May 2006
    thx :thumb:
    today we made some further progress on the medusa box and the crossfire bridge but here are some new pictures so that you can seee....
  7. The boy 4rm oz
    10 Apr 2008
    The Medusa box looks very cool as does the crossfire bridge.
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i bet who ever broke the case has viewed the project log here or where ever else you have posted it all, and got jealous and had to break it. immature little F***!
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    :jawdrop: ... again!
  10. thechoozen
    9 May 2006
    thx m8´s!!:clap::clap::clap:
    today we made some further progress on the cf-bridge.....we made a backside for it so that the real bridge is fixed between both layers....we also started a cover for the first gfx card...but its only a rough cut up to now......
    beside that we nearly finished the medusa 5.1 box....
  11. brinkz0r
    brinkz0r New Member
    15 Dec 2006
    The medusa box is very well executed, and you gotta love that CF bridge!
  12. Mokey Mokey
    Mokey Mokey New Member
    9 Mar 2009
    I too love how you took time to make the crossfire bridge look sexy! :blush:
  13. perplekks45
    9 May 2004
    It's that attention to detail that made me vote for you in MotM. :)
  14. The boy 4rm oz
    10 Apr 2008
    +1billion lol
  15. luis_pedro_Sato
    luis_pedro_Sato Member
    29 Nov 2004
    Love your work
  16. .Fatality.
    .Fatality. New Member
    10 Jul 2008
    totaly like it! awsome case!
  17. thechoozen
    9 May 2006
    thanks for all your comments!!! :clap::clap::clap:
    Today we made some small feets for the medusa box.....after everything was cut out.... we glued the parts together.....sanded + polished everything.....after that we attached them to the medusa box....et voila....nearly done....
    as next we will change the red Power Led for a green one and change the color of the poti ....
    beside that a package with sleeving material arrived so that we can overwork that part too....(not everything on the picture is for the cosmos)....
  18. thechoozen
    9 May 2006
    today we made some progress on the gfx card cover....
  19. thechoozen
    9 May 2006
    today we bended an old piece of mesh which only lays around so that it fits inside the hole of the gfx card cover....
  20. The boy 4rm oz
    10 Apr 2008
    When will you guys stop lol. The medusa box turned out superbly and the GPU back plates are looking just as good.
