Case Mod - In Progress Cosmos S ''Black Edition''_Watercooling [eVga 790i Ultra, 280GTX, D-Tek Fuzion v2..]
Discussion in 'Project Logs' started by manyga, 29 Aug 2008.
  1. manyga
    manyga Cosmos S ''Black Edition''
    29 Aug 2008
    I'm going to build my new project with a lot of pics!
    With:
    D-Tek Fuzion v2
    Thermochill PA120.3 con 3 Yate loon D12SH-12
    DDC 3.2 18w
    XSPC Reservoir top
    Feser One Black UV Liquid
    DD ''Fat Boys'' Racores 1/2''
    Tygon R-3063
    EK-FC280
    Scythe kaze master
    OCZ XTC
    Hardware:
    C2Q Q6600 @ 3.800mhz
    eVga 790i Ultra SLI
    OCZ 2x1GB PC3-12800 CL7 DDR3 @ 1800mhz 7-6-5-18
    Asus 280GTX 1Gb
    2x Seagate Barracuda 500Gb 7200.11 32mb
    Corsair VX550w
    Samsung SM 226BW 22''
    Creative GigaWorks ProGamer G500 THX
    Logitech G3 / Logitech G25 Wheel
    Sorry for my bad English....This solves with a lot of pics! haha
    Regards from Spain
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Looks great. I wish the geforce card was black pcb though.
    Do you have any sketches?
  3. manyga
    29 Aug 2008
    All components arrive!
    Pics:
    Here pump DDC 3.2 and restop XSPC, perfect combination!
    The radiator Thermochill PA120.3, the best triple radiator!
    The hose Tygon R-3603 1/2''
    Danger Den ''Fat Boys'' (G 1/4" Thread, 1/2" OD)
    Danger Den Male to Male G 1/4''
    Bitspower Crystal 90 Degree Fitting
    EK-FC280 GTX SLI - Acetal
    Regards!
    D-Tek Fuzion v2. box
    And the block:
  4. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I think I speak for everyone when I say
    Ooh! Shiny:)
    have you actually got any designs? or is it just going to be played by ear?:p
  5. manyga
    29 Aug 2008
    Yes, are these:
    Wich its the best loop for me??
    With this:
    Wich is better?
    This??
    Loop 1: Pump-> VGA -> CPU -> Rad-> Res -> Pump ( This loop is more clean and less restrictive)
    This??
    Loop 2: Pump -> Rad -> CPU -> GPU -> Res -> Pump ( Use a Bitspower Crystal 90º Fitting in pump exit or no use 901 fitting, I think thats the best option!)
    Or other??
    Thanks!
  6. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I think the first one would look a lot cleaner / nicer / simpler. Watercooling is nice, but when you have a lot of tubing, it hides all the goodies that its meant to be cooling, and I'm sure if your buying expensive stuff, you want to be able to see it. Just my opinion
  7. bigsharn
    9 May 2008
    the thing that I can't get over... your Res isn't going to be visible in the case at all...
    If the case has gone to the Anodiser's then how can you put a window in it for people to see your goodies within? (or so to speak)
  8. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    loop 1 look cleaner!
  9. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    The thing I don't like about the pump/res combination is that you normally would put the res in the top of the case, and the pump on the bottom. Now the res is at the lowest point of the loop so all of the air will get stuck inside your radiator.
  10. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Loop 1 is by far the best way to route your loop :thumb:
    .....and i don't know where that myth started but no way will air will get trapped in the radiator for any length of time with that amount of flow running through there - air will always be forced round to the res whether its at the highest or lowest point:)
  11. StrikerOfDeath
    StrikerOfDeath What's a Dremel?
    26 Jun 2008
    my suggestion
  12. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I learn something every day, tnx ;)
  13. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    I would suggest that as well.
    Common rule of WC is always go Res => Pump => Rad => Components... Then again, it shouldn't matter THAT much, but it's cleaner most of the time.
  14. manyga
    29 Aug 2008
    Thanks everyone for suggestions!!
    Update:
    I dismounted the Cosmos S for black mat powdercoating!!
    Regards!!
  15. CrixD
    CrixD Teh LoLlandic fool :o
    30 Dec 2007
    bandwidth is exceeded mate :)
  16. tominated
    tominated What's a Dremel?
    28 May 2008
    beat me to it
  17. _-..zKiLLA..-_
    _-..zKiLLA..-_ What's a Dremel?
    8 Jan 2008
    aww i wanna see it!! lol damn bandwidth
  18. Nooby4Ever
    Nooby4Ever 2 left hands
    19 Jul 2008
    Upload on another site....
  19. The boy 4rm oz
    10 Apr 2008
    From what I can see (without pics) you got yourself some nice tech there. Can't wait to see how this unfolds.
  20. manyga
    29 Aug 2008
    Some pics fixed!
    Sorry for my problem with my image hosting...
    The rest of pics will are fix soon!
