Case Mod - In Progress Cosmos S slow build
Discussion in 'Project Logs' started by skullen, 3 Mar 2012.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Soon be time to give my Cosmos a bit of a makeover.
    Few new bits and bobs.
    How it looks at the mo
    Ive started on the panels there the same as the ones ive got in the case now but newer alu and carylic panels then they will be covered in vinyl.
    This build will be a bit of a slow start as i am still waiting on a few bits to arrive.
    Some pics where i am at the mo
    New floor panels using acrylic alu plate and angle
    Panel to cover the side of the bays
    Ready for cut outs
    First cut done and finished panel
    Not sure what im gonna do at the front yet so ive cut two panels for the front
    Still need some work on them but im happy at the mo how they look.
    How i hope they will look after some more work on them before and after.
    covered some panels in carbon fibre white vinyl.
    Not the best i know but they will do.
    Floor panel and side done and covered
    This panel is for the front of the bays where the res will sit on,still a few bits to do to this panel,sorry bad pic crap phone
    Stuck side panel in for a test fit
    New cpu block, flow meter pump top and Aquearo(old pic have now got the black face plate)
    New face plate on my Aquaero
    Also got a power adjust face plate but wont be using the modules you can get for these.
    Carefully drilled the three holes on the front a bit bigger for three 3mm red leds
    Got an old zalman fan controller and took some bits off
    Controller fitted to the back of the unit,the leds will run off this.
    Couple of pics of the units together
    Thats where i am at the mo soon be time to strip the case for a rebuild.
    Thanks for looking. :thumb:
  2. bulldogjeff
    2 Mar 2010
    Judging by your previous builds I would say this is going to be another top build.
    The fist bit looks superb already.:thumb:
  3. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the reply Bulldog,its very much appreciated :thumb:
  4. Martininho
    Martininho What's a Dremel?
    8 Feb 2012
    There is so much to learn on Bittech.. Im going numb already. Looks sweet.
  5. dirky90
    dirky90 Minimodder
    19 Mar 2012
    loved the original and im sure what you are doing will be great. cosmos s is still the sleekest case money can buy.
  6. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the replys,its much appreciated :thumb:
    Well its up and running but i could have done a better job on a few things.
    Its no where near as good as the builds on this forum
    Some pics
    Temps are good so thats a bonus.
    Not bad for an old git :hehe:
    Thanks for looking :thumb:
  7. jhanlon303
    7 Sep 2006
    Love the red and white and how neat all the tubing and wiring is.
    john
  8. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the reply John,its very much appreciated :thumb:
  9. dirky90
    dirky90 Minimodder
    19 Mar 2012
    ive had a look and im convinced you cosmos is bigger than mine,
    how have you managed to fit so much in it ans make it look so tidy!?!?
    amazing.
  10. Guest-23315
    Guest-23315 Guest
    Skull, any ideas to make another piece of acrylic and use it for the entire front panel? So the Aquatube and rad etc are all bolted onto the same bit?
