Case Mod - In Progress CosmosII the privilege by C.333
Discussion in 'Project Logs' started by Corsaronero333, 30 Apr 2013.
  1. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    The Privilege
    Hello guys, start a new mod hope you like it. My main sponsor is the Cooler Master Italy:
    I must also thank you for sending the Vela wood plywood for the side panels
    http://www.velasrl.com/
    We could not miss Lamptron as a sponsor, with its wonderful FC10
    Today we add another sponsor, Silicon Power With a beautiful V70 240GB SSD
    New sponsor for The Prestige.
    Corsair has sent some wonderful RAM
    CASE: Cooler Master Cosmos II
    MOTHERBOARD: Asus Z87-PLUS
    CPU: Intel i7-4770k
    VGA: EVGA GeForce GTX 770 SC ACX, 4096 MB DDR5
    RAM: Corsair Vengeance 2x4GB 1600mhz
    PSU: Cooler master Silent Pro M2 1500w
    SSD: Silicon Power v70 240GB
    Cooling: Cooler master Eisberg 240L
    case Cosmos II
    power supply Cooler Master Silent Pro M2 1500w
    Water cooling all in one
    Other materials that I'm going to use the mod
  2. Corsaronero333
    25 Feb 2012
    As the title so here is a first floor case a fantastic
  3. Corsaronero333
    25 Feb 2012
    Begins the work of dismantling
  4. Corsaronero333
    25 Feb 2012
    First phase, covering the support of the mainboard
  5. Corsaronero333
    25 Feb 2012
    second phase, coating the lower support
  6. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    Special. I like it. And I'm terribly, terribly curious as to what you're going to do next.
  7. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Can say ive never seen burlap used in a mod before.. might be interesting....
  8. Corsaronero333
    25 Feb 2012
    Thank you very much alpaca, but it will take time to assemble it all
    Hello, I hope will turn out well
  9. Corsaronero333
    25 Feb 2012
    small details
  10. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Yay another awesome to Corsaronero project to droooooool over ;)
  11. Da Vinci
    Da Vinci What's a Dremel?
    17 Feb 2013
    Very interesting use of materials there. This could be something truly unique.
  12. Corsaronero333
    25 Feb 2012
    thanks guys
    Today I examine the Cooler Master eisberg, will undergo a small change in dress
  13. Corsaronero333
    25 Feb 2012
    Here is a nice stripped to the radiator and fittings
  14. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Uh, burlap will have a crapload of static! Standoffs won't help put out the fire at all
  15. Corsaronero333
    25 Feb 2012
    no problem the burlap is natural and has no problems of flame
    Physical Properties: The jute fiber is very strong and tough (toughness is
    greater even than that of flax), but rather rigid and inelastic. And 'anti-static and
    with a good thermal conductivity; absorbs and retains much moisture.
  16. Corsaronero333
    25 Feb 2012
    A small view of the fittings
    Waynio likes this.
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    More sweet eye candy :) some nice interesting looking windows & dials, awesome natural colour scheme once again from the materials, the eisberg looks 100x nicer stripped & clean. :clap:
  18. Corsaronero333
    25 Feb 2012
    thanks Waynio
    First change rectangular porthole for today, I removed the glass and put a mesh of brass for the passage of air
  19. Corsaronero333
    25 Feb 2012
    To exit the norm today I prepared this little innovation.
    I lined tubes blacks dellla Cooler Master with kitchen twine normal.
    The only drawback that the string is very clear and does not fit with the rest of the canvas, so I will make a small change.
    A nice cup of hot tea, leave to soak for about 3 hours from time to time check the coloring keeping a darker tone, because when it dries it loses intensity.
  20. Corsaronero333
    25 Feb 2012
    At the end I have my tubes coated and the same shade of burlap internal
    NoobNeb likes this.
