Case Mod - In Progress CosmosII the privilege by C.333
Discussion in 'Project Logs' started by Corsaronero333, 30 Apr 2013.
  1. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Definitely looks unique and interesting. I don't think there are a lot of maritime themed mods.
    I also didn't think I'd ever see tea being used as a modding tool. :)
    Those brass port holes look really massive though. Do you think you will need to reinforce the case in order to mount them?
    Anyways, good luck with your project!
  2. Boorach
    Boorach Minimodder
    16 Feb 2013
    Loving the theme for the build. Subbed to make sure l don't miss any updates.
  3. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    hello, for the portholes weigh no problem but the case is massive
    thank you very much Boorach
  4. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Real Brass?
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice match with the usage of tea. :D
  6. chris182
    chris182 What's a Dremel?
    6 May 2011
    Now as I Englishman I hate to see tea wasted, but if it has to be wasted at least it's going on a very interesting build!
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Very interesting materials. Subbed!
  8. Mad_Bull
    Mad_Bull What's a Dremel?
    8 Dec 2011
    Great job corsaronero!!! Have you been diabolical with the rope!!!! ehehehehehe ;)
  9. Corsaronero333
    25 Feb 2012
    It is real brass TheGreatSatan
    Eheheheheh news that the
    Thank you very much chris182
    Thanks to you too quizz_kid
    Thank you very much Mad_Bull
  10. Corsaronero333
    25 Feb 2012
    Today boys difficult task, puncture the side panel.
    First, prepare a sheet of plywood 5mm or so that I will clothe you, I'm still very undecided what to do
  11. Corsaronero333
    25 Feb 2012
    Prepare the exact point of drilling with the aid of the plate against brass
  12. Corsaronero333
    25 Feb 2012
    Once you place the hole in the door and begin to see the operation
  13. Corsaronero333
    25 Feb 2012
    or last 3 pics number to view the positioning of the ventilation grille and tools
    The_Crapman likes this.
  14. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Looking great so far :thumb: Can i ask what you used to remove the paint off the rad and fittings? The rad looks pretty much identical to the Alphacool ST30 240mm rads i stripped.
  15. Corsaronero333
    25 Feb 2012
    Hello The_Crapman to remove the paint I used a product of Max Meyer "BioSvernimax"
    http://www.maxmeyer.it/it/altri-prodotti/biosvernimax.html?pad=24
    You're right for the radiator is equal to 'Alphacool 240mm ST30
  16. Corsaronero333
    25 Feb 2012
    Changed the dress to the Cooler Master Eisberg 240L Prestige
    gold glitter paint is pulled vertically to give the appearance of aged satin
  17. torment lm
    torment lm Danish Viking
    25 Jan 2013
    Just amazing. Really like the scheme.
    Subbed :thumb:
  18. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    I've subscribed!
    You do know how to keep your crowd wanting more!
  19. Corsaronero333
    25 Feb 2012
    thank you very much
    eheheheheheheh :) thanks
    Here for you stripped the Cooler Master Eisberg 240L Prestige.
  20. Vandalo
    Vandalo Minimodder
    24 Mar 2011
    Ermanno as every your work also this time will be a great show :thumb:
