Case Mod - In Progress CosmosII the privilege by C.333
Discussion in 'Project Logs' started by Corsaronero333, 30 Apr 2013.
  1. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    Search and research I have also found support for LED :clap:
  2. amagriva
    amagriva Minimodder
    13 Jun 2009
    Ciao, ho sbavato su tutti i tuoi mod ma questo proprio non mi piace...
    Roba da anglosassoni steampunkabbestia
    Ho avuto il piacere di salire su qualche yacht d'epoca e ti assicuro che delle "corde" pelose non ne ho mai viste...Cime sì, con intreccio diverso e prive di pelo per usura/maneggio e salsedine.
    La manifattura, gusto a parte, è comunque sempre al top.
    Ciao
  3. Corsaronero333
    25 Feb 2012
    Non può piacere a tutti ma resta una mod da amatori, per quanto riguarda gli yacht io ci lavoro sopra e non sono d'accordo con te con le tue affermazioni
    The work may not be appreciated by everyone but it is an amateur's mod, about the yacht I work on and I do not agree with you with your claims
  4. A13X
    A13X What's a Dremel?
    25 Feb 2012
    Hi man...you are doing an awesome mod....I'm waiting for next update ;)
  5. Corsaronero333
    25 Feb 2012
    Thanks mate, soon there will be another update
  6. Corsaronero333
    25 Feb 2012
    Small update with pieces of aluminum to be painted
  7. Corsaronero333
    25 Feb 2012
    Today I show you guys how I'm going to the sleeving of the cables, but I will not use the classic sock but rather a copper wire with insulation transparent to highlight the color gold, the result speaks for itself.
  8. torment lm
    torment lm Danish Viking
    25 Jan 2013
    Different.
    Like how things have progressed :)
    Still; Love the front, :D Amusing to follow your work.
  9. Corsaronero333
    25 Feb 2012
    thank you very much.
    Also finished the 8-pin motherboard
  10. Corsaronero333
    25 Feb 2012
    Preparing the beta back, then begins painting
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Sweet mother of God! I love it!
    What does the instruments measure? Is the bottom one for some temperature sensor, the top one just a clock and the middle one for..... eh..... what?
  12. H4B4N0S
    H4B4N0S What's a Dremel?
    5 Mar 2011
    Man this mod is awesome. you are doing a greeat job on this chassis and im pretty interested to see the final result . However , will you let plastic membrane on the backpanel ?
    :hip:
  13. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    No kidding!!!!
  14. Corsaronero333
    25 Feb 2012
    Thanks for the compliments, the middle one is the barometer
    Thanks mate, it is the structure remains, but the job is not finished eheheheheh
  15. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Awesome work! :)
  16. Corsaronero333
    25 Feb 2012
    Paint the back
    Painting parts to be assembled
    First steps of the cables
  17. Corsaronero333
    25 Feb 2012
  18. Nutman
    21 Oct 2008
    So you can predict if the heat will rise or there will soon be fluid leaking inside the PC? ;)
  19. Corsaronero333
    25 Feb 2012
    Ahahahahahah:lol:
    weather
  20. Corsaronero333
    25 Feb 2012
    Here's the motherboard dell'Asus
