When I built my pc I put my sound card in the pci slot right next to my ge-force 3 with out thinking about the heat now theres only a half inch gap between them. If I moved my sound card to another pci slot would it mess any thing up ? and would i have to reinstall divers ?
If you already had something assigned to that PCI slot before, you will run into problems. I would recommend uninstalling drivers before you move it though... It might cause problems if you didn't uninstall it first
if its win2k or xp it should be fine when u unplug it and plug it back in, just make sure u have the drivers handy just in case...
if you didn't have anything there before then there shouldn't be any problem but you can always try it and if it doesn't work move it back.
