Counter-strike Source Mouse issue
Discussion in 'Tech Support' started by Skynt, 5 Apr 2008.
  1. Skynt
    Skynt New Member
    15 Apr 2007
    This actually applies to seemingly all source games. Basically, I'll be strafing or walking forward and moving my cursor to aim at something when it suddenly seems interrupted and stops. It'll only continue moving after a split second or when I re-move the mouse. It's kinda hard to describe, but basically it's like the mouse is pausing on the screen at small, random intervals. The problem just appeared out of nowhere. I've played on this laptop (it's a Dell M1530) for a while with no problems. I searched the steam forums with no avail. I don't see the mouse issue in any other games outside the source engine. It seems to occur when I'm holding down a key more often then it does when I'm just moving the mouse. Not sure if it's hardware because I've interchanged mouses, plugged them into different USB ports, etc. Honestly, I think it's my keyboard, but that's just a worry of mine (since it's a laptop :-/)
    EDIT: Further testing shows that it occurs when holding down a key or moving, not when moving the mouse. Still not sure it's the keyboard, but if it is how would I tell Dell about this?
  2. Jik
    Jik A Dremel, what is it?
    19 Dec 2007
    Is the mouse wireless or bluetooth?
  3. knuck
    knuck Hate your face
    25 Jan 2002
    It does that to me too on a random basis. It is however in 1.6/CZ and not source. The solution I found that works on older PC's is to set the priority of the hl.exe process to Low in the task manager.
    I know source doesn't use hl.exe, and I know that setting it to low doesn't make any sens... but for some reason, it does work
    Now if you can adapt this to source, and if you are lucky , it might work
    Oh and also make sure the main window of Steam is minimized
