Windows Counter Strike Source Server Help.
Discussion in 'Gaming' started by Ren, 1 Jan 2009.
  1. Ren
    Ren What's a Dremel?
    7 Nov 2008
    I have a router so i forwarded my ports using the automatic port forwarding software PFConfig and after made a CSS dedicated server.
    I tried to connect to my server using external IP and it worked! Which was great for me to be honest because it is first time i got it working, as before i did not know how to make server having router.
    The problem is that when i joined, after about 30-40 seconds the game lagged and I had connection problem error. I've looked in the console and it said as Server timed out.
    Fine i quit the game and i thought that the server would be off but it was on and working properly, in console of server it said that Player Ren has timed out or smt like that. I tried to join the server again and it doesnt work on second time, i have to restart the server to join again. But it keep doing the same thing all the time.
    Maybe some people who have hosted a CSS server know how to solve this problem?
    I dont want the server to be public and running 32 people on it, i just want to make it stable so i can set it up and play with my friends on weekends.:clap:
    Thanks.
  2. Krikkit
    21 Jan 2003
    You say you connected to it through an external IP? Are you running on the same LAN as the server? Could be a weird issue with your router connecting through itself. Got any friends to test it out on?
