Counterstrike Case for a friend-06/05 Nightshots added
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 24 May 2005.
  1. [WP@]WOLVERINE
    [WP@]WOLVERINE Minimodder
    18 Oct 2003
    Now im at it again! :D This case is a project for a friend of mine his stepson wanted a Counterstrike case so he asked me to make one for him.and since i just love making cases i agreed to do it. I started with a really crappy looking old miditower.
    This case would not win any beautycontests thats for sure. So lets make it better shall we :)
    After removing almost the entire front i used a stainless steel mesh to make a new front.
    I wanted to get some texture on thes mod so tons and tons of putty was used
    After that i drybrushed the whole thing in som dark Grey, brown and green tones
    I wanted a big CS logo on the side so i made one out of lexan and glued it in place on the side
    Then i covered it all up with putty
    And then some color
    After some more drybrushing this is what i ended up with
    For the other side i decided to make a Colt M4a1 and a Ak47. and i also made a plexiplate with the guys nick that will be lighted with a couple of leds to make it glow
    Heres the little plexi Colt :)
    unfortunatle my camera broke down so i couldnt get any pictures of the other side beeing done but heres the final result.
    A top mouted window was cut out and more putty was applied
    And guess what....More drybrushing :)
    And finally a couple of pictures as tha case stands now
    I stil have alot to do on this case like the power and reset swithes some lights and a varitey of other Counterstrikeish options to make this a case that any 14 year old CS freak would drool over :) Ill be back with updates soon.
  2. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    cool! great idea to use the plexi the way you did :thumb:
  3. Firehed
    15 Feb 2004
    Very cool! Are you going to drybrush more over the guns like you did on the CS logo?
  4. [WP@]WOLVERINE
    18 Oct 2003
    I will be adding to both the paintjob and the details. ive got some 7.62 caliber shells that i will be using to make the Start,reset buttons. I will also make casefeet out of shells and add some other goodies :) There will be some bulletholes to :)
  5. Firehed
    15 Feb 2004
    They'd better be real bulletholes, none of that dremeled junk :D
  6. [WP@]WOLVERINE
    18 Oct 2003
    Of course they will be real! I just have to clean up my AK47 that i keep under my pillow :D
  7. Firehed
    15 Feb 2004
    Nah, gotta leave it used and dirty that way it has more of a combat feel to it. Although I personally wouldn't sleep on top of a gun.
  8. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    so simple why hasn't anyone else done this before ??? realy tho great case mod I LOVE CS !!! :rock:
  9. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    That is looking very schweet, and im not 14 :p
    You planning to do anything with inside?
    Nice work
  10. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    Maybe you could also place some leds in the plexi under the drypaint, hoping it would light up a bit, use bright leds on 20ma or higher
  11. [WP@]WOLVERINE
    18 Oct 2003
    -=UPDATE=-
    The powerswitch is finished!
    First i took an empty shell
    I used the dremel to make a hole for the switch
    I had to dremel down the edges on the microswitch to make i fit inside the shell
    But i got it in there at last
    I made a bullet from a piece of aluminium
    And this is what it looks like with the bullet in place
    Ill be back soon with the reset switch and hdd/power led bullets to :)
  12. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    Nice idea with the powerswitch, very original :thumb: .
  13. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    That powerswitch idea is SO cool!
  14. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    You could start mass producing those powerswitches, but also make a few rheobus ones.
    Excellent case!
  15. .308AR
    .308AR What's a Dremel?
    8 May 2005
    Cool switch...can't say I'd like to fire that round out of one of my guns, though :)
  16. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    Drop the kid. Ask Emil "Heaton" Christensen if he is interested in it! Just kidding, he is fat and and sucks... Ask Potti instead:)
    1337 on min svenska bror! Greetings from a nordbagge!
  17. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Thats pretty dam sweet. Love the front grill
  18. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Great idea :D.
    I really can't remember any other counterstrike mods as professional as yours!
    Continue.
    :naughty:
  19. MaplinMan
    MaplinMan What's a Dremel?
    8 Feb 2003
    thats cool... looks like it should be in the corner of aztec somewhere
  20. KGB
    KGB What's a Dremel?
    4 Mar 2005
    wow, very interesting approach, before i saw the paint i was thinking "wtf is this guy doing..." then came the paint and now it stands at "daaaaamn..." very good work, great to see an original cs idea (they seem to be scarse now) keep up the good work love it
