Modding Counterstrike Window Mod [pics]
Discussion in 'Modding' started by Kyle Gagnet, 26 Apr 2002.
  1. Kyle Gagnet
    Kyle Gagnet What's a Dremel?
    7 Mar 2002
    I did this to a friend of mine's Lian-Li PC-7. Sorry about the crappy pictures. I added an 80mm fan to the top and an extra in the back. I was going to paint the fans flourescent blue, pop a uv-cc inside (it's flourescent plexi), and put a window in the hard drive but I didn't have time. I might do that eventually. I'm proud of the cutout. There ain't nothin' a jigsaw, nibbler, and round file can't do.
  2. Lord_Vheox
    Lord_Vheox What's a Dremel?
    6 Feb 2002
    Good job, real nicely done.
    Keep modding!!
  3. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I'm really impressed! Good Job!
    Did you put some molding around the edges?
    (just curious, so if I do a detailed design later)
  4. Kyle Gagnet
    7 Mar 2002
    There is molding around the top blowholw and www.caseetc.com double sided window molding on the top window. There is no molding around the CS Logo. I just put masking tape on the inside of the door and glue the whole sheet of plexi to the masking tape with Liquid Nails.
  5. Guest-16
    Guest-16 Guest
    quality job m8!
  6. brutal
    brutal What's a Dremel?
    7 Nov 2001
    wonder if you could get a piece of lexan painted ( semi-transparent) to look like a T wo the ccfl would give it a backlight glowy look
  7. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    whoa...that kicks arse! nice job bro!
  8. Vectrex
    Vectrex What's a Dremel?
    21 Apr 2002
    Wow, looks like you did a very quality job there, and spent quite a good amount of time on it. How long around did that take you to finish?
    I have yet to do a nice cutout like yours, maby I should try sometime soon? heh
  9. Kyle Gagnet
    7 Mar 2002
    It didn't take all that long...
    I cut out large chunks with a jigsaw (~30 min)
    Nibbled the rest out (~75 min)
    Filed it down smooth (~45 min)
    So i guess it was only around 2 1/2 hours to do (and I'm slow).
    Some things that slowed me down:
    Make sure you use the nibbler in a manner so that it doesn't put stress on the metal from any other direction (i.e. bend the lip down some with each cut). You probably only have to worry about this with thin aluminum, because it causes a slight discoloration of the metal (from bending it just a tad... not even visible bending, just from the discoloration).
    cheers
  10. IornRayn
    IornRayn Guest
    nibbler
    whered you get the nibbler at? and how much?
  11. neuro
    neuro What's a Dremel?
    9 Jan 2002
    v nice - just a shame really, bcoz when ur friend plays the new release of cs, its so crap ( :cries: ) he might just ask you to fill it back in!
  12. Kyle Gagnet
    7 Mar 2002
  13. therider
    therider What's a Dremel?
    11 Mar 2002
    how much did he pay ya?
    looks sweet.
    ride
  14. Kyle Gagnet
    7 Mar 2002
    200 USD
    He's really rich. :D :D :D
    (and he paid for all parts)
  15. Geek
    Geek What's a Dremel?
    21 Nov 2001
    ...proving once and for all that rich people are dumb. Nice job though.
    Gordon
    wants to be dumb when he grows up :--)
  16. boycee
    boycee What's a Dremel?
    9 Jan 2002
    anyone know where i can get one of these nibblers from in the UK ?
  17. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    Agreed neuro, ti's so easy now to crack a headshot off eh, nvmd, the lil bits make it cool.
    Btw, awesome cut out, wish i was as artistic enough to even create the rough outline let alone carry out the whole cutting, nice one mate.
