Cooling Couple of Questions...(and some renders)
Discussion in 'Hardware' started by Guest-23315, 18 Jul 2009.
  1. Guest-23315
    Guest-23315 Guest
    Im going to restart my current project/WIP but before I can start anything, I need to decided on my pump and CPU block.
    Firstly, colour scheme - Case is all clear acrylic, with green liquid and then green and UV LED's. Radiators are chromed, as is PSU and DVD drive casing.
    (project link here: http://forums.bit-tech.net/showthread.php?t=140123 )
    So, I want a CPU block. It needs to be able to take 1/2" ID compression fittings (preferably without extenders or using 45*'s) needs to be a good performer (more concerned by looks than performance though).
    I'm currently looking at these three:
    Swiftech GTZ SE
    Watercool Heatkiller 3.0
    Alphacool HF 14 Yellowstone
    Now, I like the looks of the HK, and I can nickel/chrome plate it with ease, but I want to know what the top silver bit is made from, wether its aluminium or stainless steel, so do I need to powdercoat it, or anodise it.
    The yellowstone has the right looks, but is it any good?
    The GTZ SE looks damn cool, but is a bit pricey.
    Secondly, pumps.
    Will a DDC 3.2 and an XSPC top be able to go through 2x GTS 240's , 2x GPU blocks and a CPU block, as well as a very restrictive res?
    And finally, any ideas on this res design?
    :up:
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    my vote is for the Swiftech GTZ SE :)
    it loos damn sexy!
    As for the pump it should do that setup no problems to be totally honest you just might see a small drop in flow rate cos of the res.
  3. Guest-23315
    Guest-23315 Guest
    Time for a shameless, shameless, bumping effort.
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    From what i've heard, the yellowstone isn't that great. RRR seem to dislike it alot or well at least red dose.
    I like my ek supreme lt with its acetal top, that might have enough room for 1/2in comps... if not then the heatkiller for sure. I am going to guess that little strip is stainless steel aswell.
    That Res looks like a sod for water to flow around it, maybe redesign it so there is a more direct route between the inlet and outlet, the rest would be static coolant in the channels and would look cool.
  5. Guest-23315
    Guest-23315 Guest
    As a rule from my time on XS with him, I disregard everything RRR says :thumb:
    As for the flow killing-ness, its meant to be style over substance, all show and no go etc. :p
  6. Burnout21
    9 Sep 2005
    I knew we were mortal enemies ever since you binned your dragon case! lol!
    form over function hmmmm, i prefer function thats made pretty! ROFL!
