Modding Couple of questions
Discussion in 'Modding' started by NOMIS, 30 Jan 2005.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    1. Is the measurement of fan e.g. 120mm fan the square of the fan or the hole, because I am wondering wether it would fit where I need it. So is it 120mm across the whole thing?
    2. I have seen some people paint fans before with UV paint or whatever paint, do you just do it with a paintbrush? Because only place I have found here that sells UV PAINT is in a pot so you would have to use a brush wouldn't you? How do you spray it if it's in a pot??
    Cheers!
  2. The_Gimpy
    The_Gimpy What's a Dremel?
    15 Jul 2004
    Unless you have an airbrush your probley going to have to brush it on. Why not order some in spray can if you really need to spray it?
  3. Protius-X
    Protius-X What's a Dremel?
    31 May 2004
    I'm pretty sure the frame of the fan is 120mm and the fan itself is 5mm left or so.
  4. NOMIS
    7 Jun 2004
    I would but I can't find anywhere in NZ that sells it in a spray can :(
