couple of things
Discussion in 'Hardware' started by dannyqball, 14 Jan 2005.
  1. dannyqball
    dannyqball What's a Dremel?
    22 Apr 2004
    I just built a new acrylic pc, all new hardware, I have an ABIT NF7-s2 mb and installed a Seagate 160gb hd, my system will only see 137gb. I have flashed the bios and still missing over 20gig.
    Second thing. when I scroll on my old pc the window is very choppy not smooth like before.
    Can anyone assist?
    Thanks
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    As far as the 137gb hdd problem sounds like you've not got SP1 or 2 installed. This is a common bug with XP.
  3. dannyqball
    22 Apr 2004
    I installed sp2 right after I imaged the hd. :waah:
  4. dannyqball
    22 Apr 2004
    btw I figured out the refresh rate, the scrolling is fine now. I am still in desperate need of the hd prob.
  5. Irvine
    Irvine What's a Dremel?
    29 Sep 2004
    Look for a fix on Google, I've seen a fix for it somewhere...too lazy to look it up from my PC Gamers :D
  6. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    I think partition tools like partition magic can combine the two data areas as long as you haven't formatted the 20gig.
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    When i put in a 200GB drive in my system windows actually asked me if i wanted to enable support for large drives (over 137GB).
    I have no idea on how to enable it manually, though...
  8. Hobnob
    Hobnob What's a Dremel?
    11 Jan 2005
    Go to Maxtor.com and download the "big drive enabler tool", should sort it out for you ;)
  9. dannyqball
    22 Apr 2004
    Will the Maxtor work even though it's a Seagate? :confused:
