Overclocking CPC benchmark suite score
Discussion in 'Hardware' started by flamin9_t00l, 15 Jul 2010.
  1. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Maybe I'll give mine another run, I wonder why a i5 was beating my score when it was clocked the same as my 930.
  2. flamin9_t00l
    flamin9_t00l 1,000,000,000,000 Bytes Free!
    4 Jan 2010
    Hi Demonstealth, I can actually get the system stable at 3.80 ht on, 3.90 ht on and 4.0ghz ht off but I run it 24/7 at 3.70ghz for the safer temps as I would like the chip to last a long time.
    I decided to raise the uncore by 1 multiplier to 3.15ghz while keeping all other settings the same and the final score rose by about 15 points. Don't know why I didn't try this a while ago!
    Anyway, I spent this morning reinstalling windows for a few reasons and when back up and running I did a 6 loop run of the benchmarks and this was the best of the bunch:
    Results:
    Image editing: 1598 points.
    Video encoding: 2909 points.
    Multitasking testing: 1635 points.
    Overall score: 2047 points.
    BTW some quality scores in this thread especially you guys under water. Manic Gibbon that Q6600 G0 is crying out to be overclocked. Have you not got adequate cooling?
  3. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    Downloading the benchmarks now. Very slowly. I predict a fairly low score.
  4. Demonstealth
    Demonstealth What's a Dremel?
    22 Jun 2010
    could anyone post a link to the download site please, would like to see what mine can do
  5. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Here you go Demonstealth.
  6. Demonstealth
    22 Jun 2010
    your a star thank you very much, will post results after finished downloading:)
  7. sleepygamer
    24 Apr 2010
    And here we go:
    Results:
    Image editing: 437 seconds with 55% average CPU usage.
    Image editing: 857 points.
    Video encoding: 939 seconds with 84% average CPU usage.
    Video encoding: 873 points.
    Multitasking testing: 284 seconds with 87% average CPU usage.
    Multitasking testing: 658 points.
    Overall score: 796 points.
    Told ya.
  8. Demonstealth
    22 Jun 2010
    Image editing: 1656 points.
    Video encoding: 2929 points.
    Multitasking testing: 1639 points.
    Overall score: 2075 points.
    Damn thought i'd get higher. Anyone know why using twin screens I get around 35 extra points?
  9. sleepygamer
    24 Apr 2010
    Watching a 980X system tear through these benches three times faster than my computer can do it once was a sight to behold, I tell ya.
  10. flamin9_t00l
    4 Jan 2010
    Benched my Laptop earlier today - Dell Inspiron 6400, 1.83ghz Core2Duo, 2gb ram
    average over 3 loops:
    Image editing: 622 points.
    Video encoding: 639 points.
    Multitasking testing: 431 points.
    Overall score: 564 points.
    Also ran FurMark on my 5770's CrossFireX - 900mhz core - 1300mhz (5200mhz) mem.
    What's up with the resolution, supposed to be 1024x768!! :eyebrow:
  11. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    There's nothing specific in the benchmark to take advantage of multiple displays. To be honest though, +/- 35 points when your score is already in the region of 2,000 points is within the margin of error between runs.
  12. Demonstealth
    22 Jun 2010
    hmm thats what i thought if anything I would of said that having another display would reduce the score if anything.
    Ill give it a few more goes and see what it does or see if I can get it higher
  13. Guest-56605
    Guest-56605 Guest
    This is the third loop result of my 922 @4011.1 MHz (It's default overclock)
    It's even more pleasing as its a new personal best @4GHz since I revamped the loop with new fans and coolant.
  14. bagman
    bagman Minimodder
    18 Apr 2009
    had to take off my overclock due to tempreture problems i am using a 775 water block on a 1156 board so i can only use 3 mounting poles rather than 4 so no good contact on cpu :(
    so only 1538 points overall
    i am getting a new water block very soon so will be able to do a comparisson with my new water block but till then :(
  15. sleepygamer
    24 Apr 2010
    Gah! Huge score. Niiiice.
    Okay, now get a 980X and make me even more jealous.
    And send me the 930. >.>
  16. brave758
    brave758 Minimodder
    16 Apr 2009
    Average results over 3 loops (0 failed loops):
    Image editing: 212 seconds with 10% average CPU usage.
    Image editing: 1769 points.
    Video encoding: 208 seconds with 25% average CPU usage.
    Video encoding: 3938 points.
    Multitasking testing: 113 seconds with 14% average CPU usage.
    Multitasking testing: 1648 points.
    Overall score: 2452 points.
    With a 4.1 oc. Very ruff OC though needs tweeking and i think it could do better.
    So much wasted head room and temps just pushing low 40's
  17. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    I suggest you tweak that 980x to the max! You paid a lot of money for it.
  18. brave758
    brave758 Minimodder
    16 Apr 2009
    Haha dam right,
    Nice setup mate
  19. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Overall 1830 for me running the system in my sig, overclocked to 3.2Ghz.
  20. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    Overall score: 1954 points.
    That's for my i5 750 running at 4GHz.
