Overclocking CPC benchmark suite score
Discussion in 'Hardware' started by flamin9_t00l, 15 Jul 2010.
  1. Guest-56605
    Guest-56605 Guest
    Asus hmmmmm to me just now that is a swear word!
    I had a Rampage II Gene die after less than 200 hours use it then took them 4 WEEKS AND 5 DAYS to send out a replacement by which time I'd replaced it with the GA-X58A-UD3R...
    The board they sent out as a replacement was a Rampage II Extreme which was a result I'll admit though what if my build was an mATX???
    The Rampage II Extreme now sits gathering dust so to speak
  2. Guest-56605
    Guest-56605 Guest
    Good good :D :thumb:
  3. bagman
    bagman Minimodder
    18 Apr 2009
    this is what my mums pc managed
    overall 1477
    specs
    core i3 530 @3.96ghz
    gigabyte udh3 board i think
    and 2gb ddr3 1333
    and an western digital 320gb blue i think
    i think i might have some fun over clocking it a bit more :D
  4. Guest-56605
    Guest-56605 Guest
    :hehe: What are you like???
    Any luck with the new waterblock for your own rig yet?
  5. bagman
    bagman Minimodder
    18 Apr 2009
    odd i overclocked the cpu to 4.2 and i got 1479 overall :( 2 points diffrence
    did get it to 4.4 but it wasn't stable
    i would try harder but my dad told me off and than i can't mess around with my mums computer even though i built it :(
    and i am getting a EK supreme second hand but i won't have that installed till next month as i am going to sweden tomorrow on holiday so will have to have fun when i get back :)
  6. flamin9_t00l
    flamin9_t00l 1,000,000,000,000 Bytes Free!
    4 Jan 2010
    Worst score yet:
    Results:
    Image editing: 324 points.
    Video encoding: 289 points.
    Multitasking testing: 14 points.
    Overall score: 209 points.
    Check out that multitasking score! :duh:
    System specs: Athlon XP 2600+ (Barton) @ 1.92ghz - 1.5gb ddr1 pc2700 ram @ 333mhz.
  7. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Okay, we should start a new challenge: who can get the lowest score :D
    No underclocking!!
  8. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    bet my net book can!
  9. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    Image editing: 1264 points.
    Video encoding: 1980 points.
    Multitasking testing: 1133 points.
    Overall score: 1459 points.
    Not too bad I think for stock on an i5 760, only got it this week so no oc yet.
  10. Yslen
    3 Mar 2010
    bring it on, i have a pentium 2 machine right here awaiting a PSU... :D
  11. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Don't forget you'll need a graphics card that can play back h.264 video - otherwise the 3rd test won't run.
  12. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Did mine for the first time last night and got this.
    Not sure if that is any good.
    I have a mild OC to 3608MHz and just the ATI overdrive on my HD4870
  13. Yslen
    3 Mar 2010
    I was okay on that front, unfortunately the IDE HDDs have failed completely, so the whole machine is pretty much scrap now. Not planning on buying any "new" parts for it.
  14. bulldogjeff
    2 Mar 2010
    I managed 1720 on normal speed with XMP enabled 2041 @3.5 GHz and 2173 @4GHz.
    Spec: Asus P6TD Deluxe, g-skill 1600, titan fenrir, i7 940, XFX 9800 GX2 black edition.
  15. Big Elf
    23 Apr 2009
    Just built an E8400 system from spare bits, although it does include a HD4870 that I was going to XFire in my i7 920 system but didn't coz the PCB colours don't match with:
    IE 1597
    VE 1806
    MT 1152
    Total 1518
    That's at a stable and surprisingly cool 4.2GHz. It's an old Abit IP35 XE with poor RAM dividers so I can only run the RAM at 936MHz.
  16. bulldogjeff
    2 Mar 2010
    The bench mark test doesn't seem to be a killer like prime 95, I was hitting mid to high 50's on 4GHz which surprised me a bit as my cpu runs quite hot at the best of times when it's cranked right up.
  17. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Results:
    Image editing: 657 points.
    Video encoding: 890 points.
    Multitasking testing: 503 points.
    Overall score: 683 points.
    Ouch.
    Dual Opteron 275 @ 2.2ghz (4 cores in total)
    2gb DDR400 ECC Reg HP branded RAM (4x512)
    Gigabyte GT240 512mb GDDR5
    320GB 5400rpm 2.5" Toshiba SATA2 drive
    No optical :D
  18. Demonstealth
    Demonstealth What's a Dremel?
    22 Jun 2010
    Welcome to The Custom PC Benchmarks Suite.
    Benchmarks started.
    Image editing started.
    Image editing finished.
    H.264 video encoding started.
    H.264 video encoding finished.
    MultiTasking testing started.
    Disabling Aero Glass.
    Re-enabling Aero Glass.
    MultiTasking testing finished.
    Results:
    Image editing: 1644 points.
    Video encoding: 2838 points.
    Multitasking testing: 1574 points.
    Overall score: 2019 points.
    Benchmarks finished.
  19. KD88
    KD88 Minimodder
    25 Aug 2009
    Specification as per signature but with all cores unlocked and running at 3.63Mhz
    Image editing 951
    Video encoding 1805
    Multitasking 984
    Overall 1246
    For budget build i'm quite happy with that.
  20. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Results:
    Image editing: 216 seconds with 13% average CPU usage.
    Image editing: 1738 points.
    Video encoding: 268 seconds with 34% average CPU usage.
    Video encoding: 3061 points.
    Multitasking testing: 110 seconds with 22% average CPU usage.
    Multitasking testing: 1698 points.
    Overall score: 2166 points.
    not to bad :thumb:, sig for rig spec's.
