CPU AND GPU heatsinks
Discussion in 'Hardware' started by Payne280, 21 Dec 2005.
  1. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    I'm looking for some new heatsinks for my CPU and my GPU as I'd like to do some more overclocking, you guys have any suggestions as to what would be the best heatsinks?
    also have any suggestions for some ram sinks or for some active air cooling for my ram?
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Zalman VF700 for GPU and Thermalright XP90/120 for CPU. Add a fan to suit your noise requirements and sorted.
  3. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    That sound perfect, just make sure you get the full copper VF700 :thumb:
  4. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Just a quick question which saves me having to start a new thread, Thermalright XP-120, or Zalman CNPS9500?
  5. phuzz
    phuzz This is a title
    28 May 2004
    I'm a zalman fanboy so....
    That said, being able to pick the fan to put on the Thermalright would be handy. Big fat delta for OC'ing, nice quiet pabst/panaflo etc. for day to day.
  6. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Thermalright XP-120 because you can use any fan you want (with the Zalman sink you're stuck with a fixed fan) - silence or performance
    Zalman CNPS9500 because its got better comaptibility than the XP-120
    Your preference at the end of the day.
  7. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    go for the ThermalRight SI-120
  8. hitman012
    hitman012 Minimodder
    6 May 2005
    XP-120 all the way (if it fits your motherboard). Otherwise, the SI-120 or the XP-90 will do just fine :thumb:
  9. Pie_uk
    6 Apr 2005
    true but your find it easier to sell and mount on more 939 boards, i say SI-120
  10. Payne280
    19 Oct 2005
    thx for all the suggestions i'll go with the Zalman VF700 for my GPU and for the CPU the Thermalright XP120
    but anyone have suggestions for some type of cooling for my ram?
  11. phuzz
    28 May 2004
    Main ram or graphics card ram?
    The fan on the XP-120 should provide enough airflow for your DDR ram, and I'm pretty sure the zalman comes with ramsinks for your graphics card ram.
  12. Payne280
    19 Oct 2005
    I was talking about the main ram but it sounds like the XP-120 should cover it
  13. Mister_Tad
    27 Dec 2002
    The Thermaltake Big Typhoon is just about the best youre going to get on air cooling for the moment, if it will fit in your case.
  14. Payne280
    19 Oct 2005
    would the Thermaltake Big Typhoon also cover my ram as well?
    and can I change the fan?
  15. Mister_Tad
    27 Dec 2002
  16. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    'Tis a bit annoying that you can't seem to get BTs in the UK, if anyone finds a link to what may possibly be the only good thing Thermaltake have ever made please share :)
  17. Payne280
    19 Oct 2005
  18. Kameleon
    29 Apr 2003
    Eeeeeeeeexcellent :thumb:
  19. Mister_Tad
    27 Dec 2002
    ooh cheap too
