Modding cpu and heatsink cleaning solution
Discussion in 'Modding' started by ecviper, 15 May 2009.
  1. ecviper
    ecviper What's a Dremel?
    1 May 2009
    hey guys
    anyone know of some cpu and heatsink cleaning solution that cleans off old thermal paste etc.
    i found an akasa branded one but was wondering if there is any others.
    if i wanted to do it myself with the akasa solution how should i go about it and what stuff do i need?
    thanks in advance
    eric
  2. stuartwood89
    20 Aug 2008
    I use nail polish remover, which gets it off pretty easily. Not sure how safe it is with components though :worried:
  3. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    i've used this... but 90% alcohol from your local drug store works fine...
  4. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    I just use Isopropyl Alcohol, the stuff that people use to use to clean the heads in their good old tape decks.
    I got mine for something silly like 80p by going into a chemist and asking nicely ;)
  5. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    +1 This stuff is awesome. Makes life sooooo much easier.
