hey guys anyone know of some cpu and heatsink cleaning solution that cleans off old thermal paste etc. i found an akasa branded one but was wondering if there is any others. if i wanted to do it myself with the akasa solution how should i go about it and what stuff do i need? thanks in advance eric
http://www.arcticsilver.com/arcticlean.htm Articlean is a standard. It works very well. You can also use 100% isopropyl alcohol. Make sure to use a lint free cloth as well. Coffee filters work nicely.
+1 at Joekerh. He is on a roll today. I just use kitchen roll, because I CBA to clean the TIM off properly. It's really not recommended though, I probably have old TIM and kitchen roll fibres all over the heatspreader And I'm probably gonna get beaten down for posting that I do that >.>
I worry about kitchen roll scratching a mirror surface. It is paper after all. Of course its only a problem on shiny heatsink bases and lapped CPUs.
Alcohol prep pads and a coffee filter to wipe it down.. Dunno the point of using any different liquid, what else can that Akasa stuff be made of than 100% isopropyl alchol?
"Tim Clean is a citrus based solvent and is safe to use." Quote from the Akasa site. Arcticlean TIM remover: D-Limonene Methyl Esters of Soybean Oil Non-Ionic Surfactant Thermal surface purifier: Dipropylene Glycol Monomethyl Ether Azole-Triazole Inhibitor Proprietary Inhibitor (non-Hazmat, TSCA listed) From the MSDS sheets... http://www.arcticsilver.com/arcticlean.htm
