CPU CPU at 100%
Discussion in 'Hardware' started by Pookeyhead, 20 Dec 2019.
  1. Pookeyhead
    30 Jan 2004
    When I first boot, after several seconds, the fans spool up and CPU use is at 100%. However, as soon as I launch task manager to see what process is causing this, it stops! It's driving me mental... help!!
  2. Gareth Halfacree
    4 Dec 2007
    Does the CPU return to normal if you wait and don't load Task Manager? 'cos if not, I know of several malware strains - in particular cryptocurrency miners - that watch for taskman.exe (or whatever it's called now) and go to sleep if it's loaded, as a means of making it harder to spot. Maybe worth doing a malware scan?
    Corky42 likes this.
  3. Pookeyhead
    30 Jan 2004
    I'e waiting for quite a long time... 10 minutes plus... it seems to remain in this state until I run task manager, yes. I'll do a scan and see if anything turn up and get back to you.
  4. Pookeyhead
    30 Jan 2004
    Yep!.. you were right. Norton was not even running, and when I tried to re-install it failed. I never noticed Norton was no longer running... you kind of take it for granted after a while. Something is killing Norton on start up, and hitting the CPU hard. Launching task manager kills it. Run a Norton root kit scanner at start up and it found several things... nuked 'em... all seems normal now. Gonna restore from a clean back up file, to make sure. Thanks!
    Gareth Halfacree likes this.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    You can also boot into safe mode and try Malwarebytes.
  6. Spraduke
    Spraduke Lurker
    23 Sep 2009
    That's a sneaky one I've not heard of before. Thieving buggers!
  7. Vault-Tec
    30 Aug 2015
    Sounds like a mining virus. I got one once. Was easy to get rid of though.
    I didn't even realise until I smelled my CPU rad getting hot lol.
  8. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Smelled? You're meant to use it for cooling your CPU not cooking your dinner on. ;)
  9. Vault-Tec
    30 Aug 2015
    That smell of warm dust flavored with Yankee candle. My CPU hadn't run at 100% for ages lol.
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    CPU-melted wax: technically phase-change cooling!
    Arboreal and Vault-Tec like this.
  11. nikiti
    nikiti What's a Dremel?
    11 Oct 2019
    yeah probably a mining script...be careful when you visit websites, and they are asking to allow notifications...
  12. Pookeyhead
    30 Jan 2004
    Oh I'm far too old and experienced to allow anyone, anything LOL. I very much doubt it came from a website. I have a suspicion of where it came from. All sorted now. I keep a clean windows install, with all essential software I need as a back up. I nuked it from orbit, and re-installed from a back up. Squeaky clean. Thanks.
    Arboreal likes this.
  13. nikiti
    11 Oct 2019
    good to hear that you resolved your problem
