Cooling Cpu block 1/2'' to Asetek's 10mm...
Discussion in 'Hardware' started by cool_dude, 19 Sep 2005.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Right,
    Ive got a 10mm L20 pump, and 10mm 120.1 Rad.
    Ive bought a cpu block off a mate but its 1/2''.
    I want to convert the block so it will accept 10mm tubing, and not 1/2''.
    However i am unsure of which fittings to buy! :(
    Can anyone here link me to a website as to where i can buy them from?
    thanks,
    C_D
  2. koola
    koola Minimodder
    11 Jul 2004
    Easy when you know ;)
    1/4" - 10mm barbs
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I'd just buy a new block top, is it the standard one or the antarctica you're using?
  4. cool_dude
    26 Aug 2004
    is that 1/4'' = 10mm barbs?
    Or you saying:
    1/4 BSP > 10mm ?
    edit:
    these?
    or this
    If not can you point me to a website in the UK. Cheers.
  5. koola
    koola Minimodder
    11 Jul 2004
    These ;)
    1/4" refers to the thread pitch
    10mm is the OD (outside diameter) of the tube
  6. cool_dude
    26 Aug 2004
    You deffo sure the thread pitch is 1/4'' tho??
  7. Firehed
    15 Feb 2004
    Umm, not all blocks use a 1/4" thread. And on top of that, there's 1/4BSPP (G1/4) and 1/4NPT. It could also be 9/16-18. What block is it?
  8. cool_dude
    26 Aug 2004
    Its an asetek. No worries the seller managed to find the original 10mm barbs that he took off. :)
