Cooling CPU block materials
Discussion in 'Hardware' started by Carbon, 14 Mar 2003.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    I was thinking about getting some DD stuff for a watercooling rig CPU block = [​IMG]
    I noticed that its made of copper, but is there another material other than copper that could be used for the base??
  2. kong
    kong cnc-guy
    24 Feb 2002
    Silver would be the best, if you can afford it! if not, Aluminium is popular.
  3. Carbon
    Carbon Banned
    8 Jan 2003
    :O ! silver...i never thought of that. What sort of price?
  4. adwhitworth
    adwhitworth What's a Dremel?
    12 Mar 2003
    Well if you buy the silver AC Waterblock, the upgrade is €100:eeek:
  5. Carbon
    Carbon Banned
    8 Jan 2003
    Silver AC waterblock?? Link please :D
  6. kong
    kong cnc-guy
    24 Feb 2002
    A guy over here made a water block from a silver bullion coin.
  7. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    wrong, diamond is superior, and the best known conductor of heat. Dont say its too expensive, it is, but it is the best conductor. I dont see why a small diamond piece the size of an AMD core isnt possible though.
  8. Carbon
    Carbon Banned
    8 Jan 2003
    WOAH...Thats a very expensive idea...diamonds.
    What about....:worried: Carbon? :worried:
