Cooling CPU cooler and RAM modules (M4A89GTD PRO)
Discussion in 'Hardware' started by adamix, 27 Sep 2011.
  1. adamix
    adamix New Member
    21 Sep 2011
    Hi all, looking for a replacement cooler for my AMD Phenom II 965.
    The previous one, an Arctic Cooling Freezer7, commited suicide one morning. As a temporary solution, I have attached a new 80mm(!) fan on it, using genuine Royal Mail rubber bands - the red colour option.
    I am currently leaning towards Thermaltake's Frio, or maybe the be quiet! Dark Rock Advanced (despite it not being that great for AMD systems). My main concern is whether my RAM modules will fit or not, they are Corsair's Detonators, quite tall. Motherboard is ASUS M4A89GTD PRO, and case is Fractal Design Define R2 (this should be fine).
    Any advice welcome, particularly from owners of the M4A89GTD :eyebrow:
    Thanks in advance, Adam
  2. adamix
    adamix New Member
    21 Sep 2011
    Anyone?..
  3. Guest-16
    Guest-16 Guest
    I would air on the side of caution with AMD in general if your memory heatsinks are tall. The slots are always quite close and the cooler can only be orientated one way usually.
  4. Instagib
    Instagib Well-Known Member
    12 Mar 2010
    Why not go with the Arctic Cooling Freezer7 again? You know it fits and it did the job before....
  5. TheLegendJoe
    TheLegendJoe Syntax error
    28 Oct 2010
  6. adamix
    adamix New Member
    21 Sep 2011
    True, but the Freezer7 didn't last long (just over a year). I plan to keep the pc for another 3-5 years, hopefully not having to go through this again. Most other CPU coolers have standardised fans (like the Frio's 120mm etc), which means one can always just replace the fan, should it die. However, the Freezer7's 92mm fan incorporates the brackets that attach it to the heatsink, thus preventing you from using any other standard fans.. :-(
    @Bindibadgi: thanks, sometimes I feel the IT industry should work closer to make sure we needn't have to worry about any such compatibility issues, which seem too common. Maybe mobo layouts need a rethink..
    I've looked at images online and it appears the way the Frio attaches on the mobo suggests a different orientation compared to the Freezer7 (blowing air towards the back, as opposed to towards the top). This makes me think it may be more compatible with the RAMs?
  7. adamix
    adamix New Member
    21 Sep 2011
    Sounds good, though not sure the Titan Fenrir is being sold anymore? In any case, the Frio is supposed to be the ultimate in air-cooling, say the experts!
  8. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    A lot of people use the frio to tame the heat from the AMD beasts.
  9. jeckulz
    jeckulz New Member
    18 Jan 2011
    As recommended by CPC.
    They are fookin massive though.
  10. Teelzebub
    27 Nov 2009
  11. modd1uk
    4 Sep 2006
    You may get away with using the dominators if you install those first then the cooler, dont think the dominators are as high as the vengeance ram ?
  12. MrTeal
    MrTeal Member
    27 Aug 2010
    +1, I was also going to recommend one of Thermalright's coolers, as they are quite narrow, thus making it much less likely to interfere with RAM slots, and they perform quite well.
  13. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
  14. adamix
    adamix New Member
    21 Sep 2011
    Indeed, I think they're a few mm shorter..
    Thanks for the suggestions guys, much appreciated :)
    Must confess I hadn't noticed Thermalright's cooler before.
    And Antec's compact 'watercooling' option may be worth considering.
