Cooling CPU Cooler - Dark Rock Pro or Advanced + Will they fit?
Discussion in 'Hardware' started by matt_lumley, 16 Sep 2011.
  1. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Hey guys,
    on the scan page ready to buy some stuff for new rig but i cant decide on the cooler....
    It will be cooling a i5-2500k OCd so its a choice between the Dark Rock Pro or the Dark Rock advanced!
    Also will they both fit in my Define R3 Arctic White?
    Thanks guys
  2. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    The advanced definitely fits
    The pro should also fit
  3. Kernel
    Kernel Likes cheese
    29 Sep 2003
    From the research I've done on the net. They should fit fine, although if you have RAM that has those comedy size heatsinks on them they might not fit. So you will have to looks at Low Profile RAM.
  4. Moppi
    Moppi Minimodder
    27 Apr 2009
    I have a r3 with the dark rock adv and i can say they if you need low profile ram i got the vengeance low profile white ones
  5. matt_lumley
    28 Apr 2010
    Cheers guys, also is there much benefit to the PRO over the advanced?
  6. Neilc
    Neilc Minimodder
    5 Apr 2011
    It looks great!
    Massieeeeve:clap:
  7. Xir
    Xir Modder
    26 Apr 2006
    How much is the price difference?
  8. longweight
    7 May 2011
  9. teppic
    teppic What's a Dremel?
    18 Jul 2011
    I have the Pro inside a Define R3. It fits fine, the only problem will be RAM with heatsinks.
  10. matt_lumley
    28 Apr 2010
    RAM shouldn't be a problem as I have xms3, thanks guys, will probably get the pro!
    Sent from my HTC Desire using Tapatalk
  11. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
  12. longweight
    7 May 2011
    The Pro is an awesome cooler :)
