Cooling CPU cooler for HTPC
Discussion in 'Hardware' started by Smilodon, 19 Feb 2011.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Does anyone know of a CPU cooler for Socket 1156 that have the fan mounted 90degrees in relation to the motherboard and that isn't taller than 12cm?
    It's going to cool an I3-540 in my HTPC, so it doesn't need to be high performance, but I want to utilize one of the chassis fans to draw air from the cooler (via a duct)and push it directly out of the case. The problem is that I only have about 12cm spacing for the cooler, and most I have seen so far are 13cm plus.
  2. moody89
    moody89 Minimodder
    19 Feb 2011
    The i3's run pretty cool at stock settings anyway so I would have thought the stock cooler would be adequate for a HTPC build. I'm guessing you're not overclocking or anything? Is there a particular reason you need an aftermarket cooler?
  3. legoman
    legoman breaker of things
    28 Feb 2010
  4. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    These are the ones that I'm aware of with a height of under 120mm.
    Nexus LOW-7000 R2
    Noctua C12P
    Noctua C14 (with the fan underneath the heatsink fins)
    Prolimatech Samuel 17
    Scythe Shuriken
    Silverstone NT06-E
    Thermalright AXP-140
    Thermalright SI-128
  5. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Isn't the intel reference cooler also pretty small? I appreciate there's a desire to direct the airflow, but I've had zero cooling issues with the E7200 in an antec fusion case using intel's reference cooler, which blows the air straight up. Quiet too.
    HTPC load isn't all that demanding.
  6. Smilodon
    25 Mar 2003
    Thanks guys. I'll see what I can find of those :)
    Cooling isn't the issue at all. The reference cooler is slightly noisy, so I was hoping to eliminate it. My main rig does actually run a stock cooler. The older coolers seems to me more quiet for some reason. :confused:
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I built a HTPC into an Antec Fusion a little while ago. Im using a 1156 i3 530 and im really happy with the cooler & fan i got.
    Cooler
    Fan
    The cooler performs so well with the i3 at stock, that i dont know if i even need the fan lol. But its set to pwm auto in the bios, so it only spins up when/if it is required.
  8. Smilodon
    25 Mar 2003
    Yeah, the I3 doesn't seem to produce much heat. Especially when it sees a maximum load at about 4-6%. ;)
    That Titan cooler looks very nice, but I'm still to find a shop in Norway that sell them. We had a good shop that specialized in case modding and overclocking equipment. They even made their own coolers which were pretty good but as with all other shops, they got bought and now they are basically just like every other shop. :(
    Maybe I'll just cut the fan of the stock cooler and make a duct for it... :dremel:
  9. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i think any cooler that has the fan "standing up" is going to be noisy due to your height requirements. because your limited to a <120mm fan, most of which i find to be buzzy unless you can get away with very low speeds.
    if quiet is key, i would stick with a 120mm fan at minimum. a "flat" cooler like bdigital posted, only one designed for a 120mm fan would be sweet. a second low speed 120mm fan in the rear exhaust opening would pull what little heat was generated out of the case with or without a duct.
  10. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Smilodon likes this.
  11. Smilodon
    25 Mar 2003
    I'm not planning to use the supplied fan anyway. The chassis fans will do all the work. Less fans=less noise. :) I may even try to ditch the duct altogether since the chassis fans sit sight beside the CPU. I may even get away with a passively cooled CPU.
    That looks perfect! I even found a supplier on ebay that will ship to Norway. (Postage is more than the actual cooler, but still cheaper than trying to source one locally. :duh: )
    Thanks for the help guys. :D
