Cooling CPU fan error
Discussion in 'Tech Support' started by TeenGeek, 18 Feb 2015.
  1. TeenGeek
    TeenGeek Worst touch typing ever.
    11 Feb 2011
    Hey all,
    I purchased a Corsair H100i today, to go with my brand spanking new GTX 980 :). Anyway, I went to install the cooler, and the fans happened to get in the way of my 8-pin power for the motherboard. Being the novice modder that I am and aspire to be, I ground the frame of the fan down trying to get everything to fit. Now it's all running great, the blades of the fan aren't rubbing on anything and It's all nice and quiet.
    The problem is that every time I power on the system, I get a CPU fan error, even though both fans are plugged into my 4 pin CPU fan headers. If I go into the bios, then exit without saving changes, everything runs perfectly fine, with both fans spinning. (According to my BIOS, the fans are at roughly 500 RPM.
    Does anyone know how to fix this issue, without replacing the fan (hopefully without taking it all apart again too, since this all took a couple of hours.)
    Thanks!
    Kevin
    P.S.
    All hardware/OS will be accurate about ten minutes after I post. I'll be updating it right now, so everyone knows the accurate info on that. BIOS and drivers are all up to date.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Don't the fans on a H100i plug directly into the pump/CPU contact plate and then the pump is powered by the CPU fan header (set to full speed)?
    I might be wrong but last time I fitted one that's what I think I did :)
    TeenGeek likes this.
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Noizdemon is right, you should have a Y splitter for the fans. The other end of the splitter goes into the pump. Next you should see a fan header on the SATA power Cable that powers the pump. That goes on the CPU fan header :thumb:
  4. noizdaemon666
    15 Jun 2010
    Forgot about the SATA power connector (yay no molex :D), thanks for clarifying Pookie :thumb:
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Yes they do connect into the pump, go onto their website they have clear instructions. If you want pictures of how and where they connect I'll take pictures of mine to show you.
  6. TeenGeek
    11 Feb 2011
    Ah, okay, thanks guys! I just assumed that it wouldn't actually matter if I did it that way. I suppose I will get to that tomorrow.
  7. Pookie
    4 May 2010
    Just to note. I got confused with my Y splitter cable, as I couldnt see how to connect the fans! I soon realised Corsair had placed a plastic sheath over the pins to prevent them getting bent. So just slipped them off and away I went (if you have them of course).
  8. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    To add, once you've re-jigged the connections about, head back into your BIOS and set "CPU Fan Speed Low Limit" to Ignore. This will stop the error coming up if the pump is spinning too slowly on startup.
  9. TeenGeek
    11 Feb 2011
    Thanks guys,
    Those pin covers were the most difficult thing for me to figure out, since the instructions don't have anything in them about pulling off a cover in order to connect the fans. To make matters worse, they don't even have a different color for the sheathe, and since it's all black, the seam between them is not very obvious.
    After about twenty minutes of investigation, I finally figured out that they pull off...:duh::duh::duh:
    Thanks for the advice all!
