CPU Fan Question
Discussion in 'Hardware' started by ibemonty2004, 12 May 2003.
  1. ibemonty2004
    ibemonty2004 What's a Dremel?
    12 May 2003
    If I were to add a 80mm heatsink fan such as this would I be able to hook this up to the motherboard without frying the mobo? Also, if I were to attach this fan to a fan controller, would there be any problems having to do with the mobo thinking there was not a cpu fan or anything?
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    The rated current is:
    Rated Current: 0.23 A (0.276 max)
    Very small, you should be able to connect it anywhere you want.
